Tail shaft housing keeps Cracking
Discussion in 'The Garage' started by hardcore_rob, Dec 18, 2004.
  1. hardcore_rob
    hardcore_rob 1/2 ton status
    Dec 6, 2002
    111
    Colorado Springs, Colorado
    Here is what happened:
    Was driving home from work, the hardware that holds the rear u-joints came loose and came apart. The drive shaft dropped to the ground. It caused the aluminum housing to break apart, because the drive shaft didnt completely
    pull out away from the transfer case. I have since replaced the u-joints with heavy duty ones and also replaced the aluminum housing, but as soon as i got eveything on and tested it out, it had a horrible wobble and broke the housing again. I am trying to get sell the truck and am trying to figure out what could be causing this and if there is something I can do to make it more sellable. I dont want to have to replace the housing again to just have it break apart because of the wobble. By the way, it never had the wobble until the original problem occured... Any suggestions??
    any help would be appreciated..
    rob
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Your tailshaft is bent in your transfer case. Time for another transfer case.
  3. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    could also be your driveshaft is bent/ unbalanced. at work we had a 2wd truck that cracked the trans, put in a rebuilt one and it cracked again in 1 day .then we figured out the shaft wasnt straight. never had a problems afterwe had it balanced.
  4. hardcore_rob
    Dec 6, 2002
    111
    thanks for the info, i inspected the tailshaft and it looks ok, i am leaning toward the driveshaft being unbalanced, i was talking to another guy this evening and thats what he thinks as well, i imagine that the driveshaft took quite a bump when it hit, would it be cheaper for me to have it re-balanced or buy another one? anyone have a spare that they would let go for a reasonable price, what about the tail shaft housing for a np205, i would rather try to sell the truck fully ready to go, but i could cut a deal i suppose if they wanted to replace the stuff instead....
  5. Jonny-K5
    May 27, 2003
    1,654
    SoCal
    rebalancing a driveshaft usually doesnt cost that much. i think its like 40 bucks around here.
  6. hardcore_rob
    Dec 6, 2002
    111
    thanks for the info.
  7. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    Also check the yoke on the rearend. It could have gotten messed up when the driveshaft hit the ground.
