Tailgate and windshield
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by mikeperez22, Aug 2, 2004.
  1. mikeperez22
    mikeperez22 Registered Member
    May 11, 2004
    41
    Can anyone tell me how to pull off the tailgate? I tried everything I could think of. Also, can anyone tell me how to take the windshield out? I need to remove it along with the tailgate before it goes to the bodyshop next week. Thanks.
  2. 70jimmy
    70jimmy 3/4 ton status Premium Member GMOTM Winner
    Mar 3, 2000
    5,962
    252
    Released from Pueblo, told I belong in Southpark
    Tailgate you have to take the hinged support arms off of the bed sides. I just put the hinge so it is going up instead of down. Like an elbow sticking up in the air not down like when you close the gate. You close the gate partially so the shape allows you to pull the arm toward the inside of the bed. Do this to both sides and the tailgate will go down more than parallel to the ground then lift up on one side. I believe the right side comes out first then just lift the gate off.
    On the windshield I have never taken one out but I know that you have to replace the windshield gasket so most people take a utility knife and cut the front flap of the gasket off so the windshield can come out.
    Hope I explained the tailgate removal OK. /forums/images/graemlins/thinking.gif
  3. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    Petrolia,Ontario,Canada but working in Port Huron,
    That's exactly how I removed my windshield.
    Sharp utility knife and cut around the gasket.Then gently remove by pushing from the inside of the truck.
  4. JohnSPledg
    JohnSPledg 1/2 ton status
    Feb 22, 2001
    141
    Baton Rouge, La
    I used a dead blow hammer. It had been a long day, but I definately felt better afterward.
