Tailgate Glass
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bigd652, Jan 25, 2004.
  1. bigd652
    bigd652 Registered Member
    Jan 22, 2004
    26
    Michigan
    I tried to lower the tailgate glass and I heard almost a tearing sound. Now I can hear the motor running but the glass doesn't go down... Any thoughts?
    D
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Best thing to do would be to crawl back there and pull the access panel and have a look see.
  3. bigd652
    Jan 22, 2004
    26
    Michigan
    How does said panel come off? /forums/images/graemlins/laugh.gif
  4. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Phillips screwdriver, there is a bunch of screws going around the edge of the panel.
  5. bigd652
    Jan 22, 2004
    26
    Michigan
    And if I find something afoot back there.... Can it most likly be fixed with the glass up. Also the tail gate won't come down so thats not an option.... lol
  6. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Typically, yes, you can fix it........to get the glass to come down so you can lay the tailgate down flat and look, unscrew the cable from the motor, put the cable in the chuck of a drill motor and start the drill, the glass will lower /forums/images/graemlins/thumb.gif
  7. pineyjon
    pineyjon Registered Member
    Aug 23, 2003
    80
    south jersey
    it sounds like it might be a broken cable
  8. bigd652
    Jan 22, 2004
    26
    Michigan
    Well I can't put the tailgate down for fear that it will just fall off. Kinda rusty around the hinges..... So I hope that it can be fixed with the tailgate and glass up....
  9. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    If it is just the cable, you can do that with the window stuck up. if the rail at the bottom of window is as rusty as the tailgate sounds to be,(since it won't open) you might not be able to fix.
  10. bigd652
    Jan 22, 2004
    26
    Michigan
    Its not that the tailgate is rusty... Its the hinges where they connect to the body. When I try and put the tail gate down they don't move but look like there gonna break off at the body mount area....
