Tailgate gremlins
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by fr8train, Sep 16, 2001.
  1. fr8train
    fr8train 1/2 ton status
    Aug 2, 2000
    1,712
    Maryland
    My tailgate wont go up that last 1"-3/4". I am inda confused cause it worked great up till now. I cant see anything in the track. It stops dead even if I push up on the lift arms. The motor is a new gm unit. Any suggestions?
    <a target="_blank" href=http://community.webshots.com/user/thatguydrew23>http://community.webshots.com/user/thatguydrew23</a>
  2. Confederate9
    Confederate9 1/2 ton status
    May 29, 2000
    1,686
    Greensboro NC
    try checking the grease, re grease it, then also check ur battery mine did that right b4 my batt died
    and in the winter sometimes the grease freezes, but tis not winter so thats ruled out
    <font color=red>K5: Because size DOES matter</font color=red>
    85 K5 4IN LIFT 35 GOOD YEAR WRANGLER MT/R, AMERICAN RACING WHEELS
  3. fr8train
    Aug 2, 2000
    1,712
    Maryland
    Its greased. I coated the rails and tracks with moly and then heat brazed it to get the moly to stick/coat the metal. Then applied grease to the rollers and tracks. Butter smooth just wont go up. Looked at the seal too no bumps or anything. Really confused about this one.
  4. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    If you pull/wiggle the window while trying to power it up, will it go? Mine does that with like 4-5" left; I think it gets hung in the tracks or something...
    September 11, 2001--"A date which will live in infamy"
  5. MOABDADC22
    MOABDADC22 1/2 ton status
    Jul 24, 2001
    1,348
    Cheyenne, Wy
    Mine did the same thing. The bottom channel that the window is glued into was hitting the motor. I had to bend the motor away from the window just a little bit and it has worked fine since.
    <a target="_blank" href=http://www.moabdadc22.alloffroad.com/>http://www.moabdadc22.alloffroad.com/</a>Real four wheelers don't need tools to remove body panels, paint, tail lights..etc.
  6. fr8train
    Aug 2, 2000
    1,712
    Maryland
    Hmmm... I dont know about the track movement Jarhead will take a look at it tommorow. I am curious about the motor being bent in a little more as well.
  7. Jonathan
    Jonathan 1/2 ton status
    Apr 14, 2001
    293
    Little Rock, Arkansas
    Be sure your top is lined up right. Mine did that once and I loosened up the top bolts and moved it around till the window would go all the way up then tightened them back down.
    77 Blazer, 350, NP203, K&N, 31-inch Cooper Discoverers
    <a target="_blank" href=http://community.webshots.com/user/jonathandwill>http://community.webshots.com/user/jonathandwill</a>
  8. tRustyK5
    Jul 23, 2000
    36,170
    1,380
    E-town baby!
    I think Moab is on track (pun intended...[​IMG]) usually when the window stops dead without making it to the top its geting hung up on something. There's not that much room between the moving parts in there.
    Rene
