tailgate mechanism
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by coolhandluke, Dec 21, 2001.
  1. coolhandluke
    coolhandluke 1/2 ton status
    Oct 23, 2001
    116
    Dallas Texas
    My tailgate won't go down when I pull the handle on the inside. It's jammed somehow. I have taken off the panel on the inside of the tailgate, but can't see in there well enough to be able to figure out what the thing is supposed to do, or how it does it. Has this happened to anyone else? an suggestions on how to fix it?
    83 k5 originally diesel, now 350, 700-R4 12 bolt rear, 33x12.50 BFG Trails (yuck), desperately seeking a lift
    sometimes nothing is a real cool hand
  2. dyeager535
    26,979
    I'm relatively certain there is something in the tailgate that is supposed to let it be opened only when the window is all the way down. It may be right at the bottom of the access panel opening, as I believe the bottom of the window hits a piece there (has a small spring attached to it) when it opens. Certainly sounds like the problem.
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>www.dorianyeager.com/index2.html</a>
    Why insist on counting when the ring gear has the tooth counts stamped in?
  3. RAY
    RAY 1/2 ton status Premium Member
    Jul 4, 2000
    281
    Austin, Texas
    Mine kinda sticks sometimes, so what I do is push in on it and while I am lifting the handle. Hope this helps.
    Ray
  4. coolhandluke
    Oct 23, 2001
    116
    Dallas Texas
    okay, neither of those ideas worked, any others? I can't move the mechanism at all, it's like it's bound up somehow...
  5. Mudstud
    Mudstud 1/2 ton status
    May 29, 2001
    1,472
    Memphis, TN
    My bet would be that something is jammed at the sides of the gate, where the latches engage the bed rails. Don't laugh but maybe if you spray some wd40 along the sides of the gate and then hit the gate real hard with your hand to unjam it at the same time pulling the handle. You need 2 people! That's about all I can offer. Good luck
    Mudstud
    <a target="_blank" href=http://communities.msn.com/OffroadK5s6superliftand33s.msnw?albumlist=2>http://communities.msn.com/OffroadK5s6superliftand33s.msnw?albumlist=2</a>
    76K5 6" with 33s, sb400/350/203parttime/3.73-D44/GM12bolt
  6. dyeager535
    26,979
    I figure this is probably the least of your worries, but since there isn't much other input, why not try pulling the two "bars" that run to the center near where the handle is? Pull both of them towards the center, and that will unlatch the tailgate. (if whatever is stuck allows you to pull them) Once you get it open, you may be able to see whats going wrong in there in the daylight.
    Dorian
  7. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    I have to open mine from the left side and the left side ONLY! I tried toi straighten the mechanism inside but it went right back to "normal". Try pulling from one side or the other,
    That jeep thing? Yah I understand it....... Like my Blazer? <a target="_blank" href=http://community.webshots.com/user/blazerk5>http://community.webshots.com/user/blazerk5</a>
    Jim
