Tailgate problems on 72
Discussion in 'The Garage' started by raptorGTA, Dec 30, 2003.
  1. raptorGTA
    raptorGTA Registered Member
    Aug 21, 2001
    16
    When I open the tailgate on my 72 Blazer the latchs that hold the tailgate to the body do not return to the out position. I also don't see an access panel on the tailgate to look inside. What can I do to fix it? Thanks
  2. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    see any rust on them? try spraying some pblaster in them.. are they bolted on?
  3. raptorGTA
    Aug 21, 2001
    16
    I have tried to use WD40 and it didn't work. Also forgot that when I pull the handle to open the tailgate I have to push it back closed and then pull out the latches with channel locks. Thanks
  4. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    Petrolia,Ontario,Canada but working in Port Huron,
    There are 3 bolts on the inside of the tailgate.Loosen those 3 bolts.You can adjust the tailgate lever that way.
    Mine was kinda tight as well untill I sprayed some WD40 and readjusted those 3 bolts.
    Give it a try and see what happens.
