tailgate problems
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 88jimmyoungowner, Nov 26, 2001.
  1. 88jimmyoungowner
    88jimmyoungowner 1/2 ton status
    Nov 20, 2001
    425
    georgia-rome
    my 88 jimmy has a tailgate that you push and tug on a little bit before you get it open. Is this normal, and just needs a little grease, or is it a bigger problem?
    16, 88 jimmy, give me advise if i ask for it, please!!!!!!!!!!!
  2. Mr.Chevy4x4
    Mr.Chevy4x4 1/2 ton status
    Jun 16, 2000
    1,932
    Sims, NC
    The handle that you pull up on to release the tailgate pushes on a rod that releases the latches. Where this handle attaches to the push rod has a tendency to bend and the rod doesn't get pushed far enough to release. I pulled mine out and welded a small brace in there so it won't bend anymore. This is the problem I was having with mine. If there is something else that causes the same problem I don't know what it is. Good luck!
    '85 K5 : Run it til it breaks, then fix it and go again!
  3. shawnboy
    shawnboy 1/2 ton status
    Jun 22, 2001
    468
    Toronto, Canada, eh.
    Mine does the same, push and pull at the same time. My '90 has a sprung rod on either side which holds it tight, no rattles, but otherwise it works fine.
    Shawnboy.
    <font color=red>If you are having too much fun it's probably illegal.</font color=red>
  4. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I have to push my tailgate in with my chest, pull the handle and then pull to get it to open. It has been this way as long as I can remember, and its normal to me.
    My Chevy isn't broken, its just out of gas.
  5. kpanza
    kpanza 1/2 ton status
    Dec 8, 2000
    1,579
    Lake Forest, Orange County, California
    Just like the other guys have said, this unfortunately seems to be normal...that design they used for the handle is very weak and will break eventually. I just broke mine finally, and Chevy reamed me for $70 bucks for a new one!! If it wouldn't have been raining and I felt like sogging through the mud to look for a used one in the junk yard, I might have been able to find one cheaper - but most likely the ones in the junk yard will be bent already!! [​IMG] I am the only one who can open the tailgate, everyone else laughs at my "push-pull" method. Oh, and one other thing I learned, is DON'T let anyone else try to open it if they don't know what they are doing - this is why they bend, because people don't know how to open it "properly"!!!
  6. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    Look up at the top of the inside of the gate, see those two pins? Those go in the holes on the top of the tailgate posts for a little more stability/strength. Provided that gap on your gate is still good, its an easy fix. You need a pry bar and a hammer to adjust them. You do want them to grab a pinch, but nothing excessive when they go in the holes. You can see by how they are shaped to tell how they work.
    <a target="_blank" href=http://new.wavlist.com/movies/031/ag-blow.wav>"I ain't nobody, dork."</a>
    <a target="_blank" href=http://www.geocities.com/bigkern76>http://www.geocities.com/bigkern76</a>
