Tailgate Probs.....
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BlaznRebel, Dec 15, 2002.
  1. BlaznRebel
    BlaznRebel 1/2 ton status
    Sep 1, 2002
    115
    Louisiana,Baton Rouge
    OK here goes i've tried and tried to fix my rear gate and it won't stop bouncing. I adjusted the latch inside the bed but it still bounces and bangs every bump I hit. Has anyone else had this problem? Also can it be fixed without have to buy a new gate?thnx /forums/images/graemlins/1zhelp.gif
  2. mch
    mch Registered Member
    Oct 20, 2002
    7
    Las Vegas, NV
    I recently got a K5, and a previous owner had put locks on each side at the top of the tailgate. Hard to describe but kind of like flush deadbolt for cabinets. I took them off to paint, and see how much the tailgate now sticks out without the installed locks. I'll probably put them back on.
  3. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    pics please! I'm looking to get my tailgate lock recored but this is an interesting idea if the deadbolts could be lockable! /forums/images/graemlins/thumb.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/deal.gif
  4. Grim-Reaper
    7,385
    Atlanta
    latches are wore out . If you look at the latch on the body it's going to have a groove wore in it. The latch in the gate will have the same problem.
    I haven't had time to fix my wifes 79 for the same problem. You cna fix both with a welder and fill the low spot and reshape with a grinder. The rest of the equasion is a new gate seal that isn't hard as a brick.
  5. BlaznRebel
    Sep 1, 2002
    115
    Think i found the problem... I went to Wally World to pick up a new TV and when i got home and went to take it out i realized that one of the carrige bolts was sticking up out of the bed.started looking and both of the back bolts don't have nuts on them and i can take them out. Think that could be where the banging is coming from? hehe
  6. mch
    Oct 20, 2002
    7
    Las Vegas, NV
    Well luckily I took a bunch of pictures from when I 1st bought it, and various times during the body work process. Here's a link to the best pick I have of the locks. If you can't make them out, you got 1 component screwed into each side. 1 side is a simple loop, and the other has the deadbolt/pin. It locks into place, but it isn't lockable like needing a key or anything. I'm not planning on making it a show truck or anything, so it does what is needed.
  7. Grim-Reaper
    7,385
    Atlanta
    Bootie fab at it's finest! You could put them on the inside just as easy I bet /forums/images/graemlins/smile.gif
