tailgate question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Doug, Oct 3, 2001.
  1. Doug
    Doug Registered Member
    Sep 1, 2001
    56
    Northern Colorado
    I don't have a owners manual with my newly acquired Blazer, does the key for the tailgate also control the window (mine doesn't now), or does it work only with the swith on the dash. Newby questions I know, but I don't know.
    '85 k5, 350, 700r4, np208, 10 bolts, as of 10/2001; wish list is extensive.
  2. Itali83
    Itali83 1/2 ton status
    Feb 12, 2001
    795
    Westbrook Maine
    The door lock key DOES work the tailgate window from the outside, the reason yours dosen't work is because the switch is broken. I'm betting that 9 out of 10 tailgate keys don't work because of a bad switch. It isn't that bad to fix it but looks a lot harder. You basically need to take all the guts out of it to get to the outside switch, then replace it and put it all back together. Hope I helped.
    Be 87 JImmy
    <font color=blue>Rust=Bad</font color=blue>
    <a target="_blank" href=http://www.bens87toy.alloffroad.com>www.bens87toy.alloffroad.com</a>
  3. Burbinator
    Burbinator 1/2 ton status
    Sep 14, 2001
    898
    Tempe, Arizona
    Yes. Rotate left for "up", right for "down". You might take off the tailgate interior panel and see if the window or arm assembly has disconnected your wires for you.
    - Alan
    '91 2500 Suburban Silverado 4X4
    '82 K10 Suburban Silverado
    Always do sober what you said you'd do drunk. That will teach you to keep your mouth shut!
  4. Capman2k
    Capman2k 3/4 ton status
    Jun 22, 2001
    5,070
    dg
    how about for those that only go down with the key? Same story or what?
    79 K5 Blazer Cheyenne.... That's all I have to say about that.
  5. Burbinator
    Sep 14, 2001
    898
    Tempe, Arizona
    Should be the same operation for those as well.
    - Alan
  6. NE79
    NE79 1/2 ton status
    Mar 10, 2000
    177
    Nebraska City, NE
    I was very pleased at how easy it was to tear down the tailtgate. Took me about 2 hrs. to take it apart, grease it, clean the safety switch and put it back together. Very easy.
    uh-oh
  7. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    thats why im glad i have a custom deluxe... manual windows and locks.. no fusess to blow.. no motors to fail =-))
    6in 87' K5 w/ 35" BFG muds.
    305/Sm465/ NP208, 4.11's coming soon.
    Kn filter
  8. taterblazer
    taterblazer 1/2 ton status
    Feb 2, 2001
    277
    Boise, ID
    Rear window concerns..
    I really don't like the rear window at all! Power rear window sux big time. Anybody know of an inexpensive manual kit?
  9. DieselDan
    DieselDan 1/2 ton status
    Jan 27, 2001
    1,056
    Vermont
    Re: Rear window concerns..
    I'm with you Tater. That power window is a pretty big electrical drain (not running), even with dual batteries. I frequently go camping and you have to secure all your food in your vehicle (bear problem, ya'know). Window up, then down, repeat as beer holds out. If I trip over a manual crank mechanism (or the power window craps out) I'll replace it.
    Real trucks don't have spark plugs!
  10. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    Another thing to check for is to see if it has juice. There are three wires running to the gate for power. Brown is for down, blue is for up, and orange is the constant hot to run the key switch. That orange one should have juice for the key to work.
    <a target="_blank" href=http://www.geocities.com/bigkern76>http://www.geocities.com/bigkern76</a>
  11. Espen88k5
    Espen88k5 1/2 ton status
    Feb 19, 2000
    981
    Norway
    I have a mini-write upp on my page if you want to look at tailgate guts. Link below:
    <font color=red><a target="_blank" href=http://www.espen88k5.alloffroad.com>www.espen88k5.alloffroad.com</a></font color=red>
