Tailgate replacement
Discussion in 'The Garage' started by fireplug, Apr 12, 2006.
  1. fireplug
    fireplug 1/2 ton status
    May 3, 2005
    1,692
    Toronto, Canada
    I understood that the P/U tailgate was a direct bolt on, so I assumed that meant any fleetside from 73 - 87, now I hear they changed, "the gates changed in 79/80 to 81 up".
    Can anyone tell me what year P/U I should be looking to use for my '76 Blazer.
    Thanks guys. Jason.
  2. rdn2blazer
    rdn2blazer 1 ton status Premium Member
    Jun 9, 2004
    16,487
    1,192
    So Cal.
    I keep hearing there was year changes but I bolted my 89' factory taligate up to my 73' Blazer and it fits fine.
  3. dremu
    Feb 27, 2000
    15,968
    461
    East of San Francisco
    LMC lists different #'s, but I think it's cosmetic, i.e. shape of the indent on the back. I *believe* the mounting is the same, so as long as you don't need a "correct-for-your-year" look, use whatever you like.
    -- A
  4. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    yes, its just the shape and i think the depth of the indent in the tailgate that is different. they did change the latch on the tailgate in 75 or 76, but i believe they will interchage with each other.
  5. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    I installed an '82 pickup tailgate on my '73 and another '82 on my '75 K-5's
  6. fireplug
    May 3, 2005
    1,692
    Toronto, Canada
    Thanks for the help guys!
  7. R77K10
    R77K10 Banned
    Mar 15, 2006
    564
    Lincoln IL
    yeah they changed from non-removable gate(not rmeovable without having to unbolt a pivot) to the rmeovable ones(gate has a slot in bottom of one end so you can lift it off the pivot)
    have to watch that
    but its an easy fix if you swap the style of pivots
    some of the 77-up changed some didnt and then 81 up in most cases
    it seems very random
    some trucks of the same year seem ot have one or the other and you jut never know which
    but anyways yes they changed, but you can jut swap the pivot(s)
    no real big deal
    good luck
