Tailgate Spring - Is it a PITA to remove?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 1986Blazer, Dec 8, 2001.
  1. 1986Blazer
    1986Blazer 1/2 ton status
    Jun 13, 2001
    511
    Key West, FL - Southernmost Point
    I am designing my new rear bumper and found that the spring that supports the tailgate is hooked to one of the factory bumper mounts. When I remove this bracket to install the new bumper - what is the procedure to remove and reinstall this. Is it loaded, and if so will it take off my hand when I remove it. Is it easy to reinstall? Thanks for any responses.
    <a target="_blank" href=http://www.geocities.com/keywestk5/KeyWestK5.html>http://www.geocities.com/keywestk5/KeyWestK5.html</a>
    So I says to him, I said, "get your own monkey."
    1986 K5, 350 GM Crate, 700R4, NP208
  2. BigTex
    BigTex 1/2 ton status
    Dec 27, 2000
    974
    South Texas
    Its not hard to take off. I did it by myself but it took a lot longer than if I would have had help. It won't pop out or anything. I just pryed if off with a screw driver.
    <font color=red>"SETTING OFF ALARMS IN A CITY NEAR YOU!"</font color=red>
    <a target="_blank" href=http://coloradok5.com/gallery/BigTex-Mean-Machine>http://coloradok5.com/gallery/BigTex-Mean-Machine</a>
  3. 1986Blazer
    Jun 13, 2001
    511
    Is it the same way to reinstall? Use a screwdriver and pry it back onto the bolt? If you had to do it again, are there any special tools you would use?
    Chris
  4. BigTex
    Dec 27, 2000
    974
    South Texas
    It is the exact same way to reinstall. I studied it for a bit and figured the only way to do it was to just pry it off with a long screwdriver. It's not under extreme tension, and to be honest with you, I don't know if there are any other tools that would make the job easier. At least not that I know of.
  5. Michael
    Michael 1/2 ton status
    1,576
    Sherman, Texas
    The spring is not loaded when the gate is up....it is very loaded when the gate is down.
    Michael[​IMG]
    <a target="_blank" href=http://www.jmartin.net/parker/goose.htm>www.jmartin.net/parker/goose.htm</a>
  6. jcg
    jcg 1/2 ton status
    Mar 19, 2000
    660
    Rochester, NY
    I took mine out when I rebuilt my tailgate, they're not hard to get out at all. When the tailgate is up it's not under any load so just take out the bolt. I left mine out since I knew I was doing a body lift eventually and putting on a new bumper (which I finished building today!! WOOHOO!!). It just gives you a bit of a workout when you close the tailgate, but you get used to it.
    Joe
    RIT Mini-Baja www.rit.edu/~bajawww
    Team Mudnuts www.mudnuts.org
