Tailgate tire carrier?
Discussion in 'The Garage' started by dontoe, Mar 19, 2005.
  1. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    Wonder if I could carry a 33 or 35 spare on my tailgate? It's a P/U tailgate I put on the Blazer.
  2. blazerpro79
    blazerpro79 1/2 ton status
    Jan 4, 2005
    528
    Simi Valley, CA
    i seen people put 40's on them
  3. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    I didn't want one of the bumper mounts and need the behind back seat storage. Might do that then. Wanted input before drilling holes in a good tailgate though.
  4. blazerpro79
    Jan 4, 2005
    528
    Simi Valley, CA
  5. Esteban86K5
    Esteban86K5 1/2 ton status
    3,712
    Bakersfield, CA
    If you talking about the tailgate itself. I don't think it would hold up much at all. It's only sheetmetal and it would either rip out or just bend to all hell. Get yourself a bumper mount or hitch mount.
  6. dhcomp
    dhcomp 3/4 ton status Premium Member
    Mar 17, 2001
    9,862
    295
    Truckee, CA
    I second esteban......get a good quality bumper mount.....or make it an excuse to get a new bumper wiht swing out tire carrier :)
    And even if you did mount it to the tailgate, how would you open the tailgate then?
  7. rocknutah
    rocknutah Registered Member
    Feb 7, 2005
    61
    slc utah
    If your dead set against a bumper mount try fabricating a bedcap style plate running from top to bottom, allowing clearance for the gate to open.
    you might want to run a plate out at a 90 degree angle to the face of the gate, to help support the weight of the tire & wheel, along with what ever you use to hold the tire to the gate. Make sure the lower support is high enough to clear the bumper (if you have one) when the gate is down. I would probably consider running plate end to end, build a heavier hinge & latch set up, with safety cables, just in case. Like they said it's only sheet metal. Thats alot of extra weight for the hardware to support. It would probably be easier & lighter to fabricate one from scratch. As for access to the handle, Ferrari used rope on their windows. It seem a lot more at home in a K5. Rope lift for tailgate glass, or side glass seems a pretty easy fix for a regulator you can't afford.
