Tailgate Weatherstrip
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by daleearnhardt01, Oct 15, 2002.
  1. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    I just put brand new weatherstrippin on the tailgate tonight at work(inner and outer) and now the window is slow as I expected it would be. Any good suggestions to get the glass moving good again or should I just let the rubber get broke in good? /forums/images/graemlins/k5.gif
  2. daleearnhardt01
    Aug 29, 2002
    3,223
    Richmond, VA
    Any ideas? /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/k5.gif
  3. dyeager535
    26,980
    I got the LMC one, and mine is slow too now. I'm guessing the seal just needs some use to get into shape.
    My window wasn't all that "powerful" in the first place, only thing I haven't done to help speed it up is grease the drive cable. Only time it has problems is the last couple of inches as it closes. Much less of a problem when the alternator is putting out 14 volts instead of 12 from the battery though. (vehicle running vs off)
  4. marcus
    marcus Registered Member
    Dec 21, 2001
    65
    England UK
    I've heard that a bit of washing up liquid along where the weather strip meets the glass is supposed t work wonders...a top tip from my tranny mechanic!
  5. dyeager535
    26,980
    What is "washing up liquid"? As in liquid hand soap or something else I am totally unfamiliar with?
  6. Skigirl
    Skigirl 1/2 ton status
    Apr 2, 2001
    2,563
    Los Angeles, California
    I think he's talking about dish soap or hand cleaner (which usually has oils in it, like lanolin). Just rub a little on the rubber and it will lessen friction. Should help.
  7. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    WD-40. Your window will be messy, but its rubber friendly and will stay for a while.
  8. marcus
    Dec 21, 2001
    65
    England UK
    Sorry guys! Washing up liquid in the UK is the liquid that you use to wash your dished with after eating....
    But I suppose hand soap for some such would work just as well....
