tailgate's
Discussion in 'OffRoad Design' started by **DONOTDELETE**, Mar 18, 2001.
    tailgate\'s
    Need some advice on removing and replacing the tailgate hardware. How do you remove the handle and crank from the tailgate. I need to replace the interior parts on my 75 Blazer (manual crank).
  1. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    Re: tailgate\'s
    well while were here, a picture of the back of what I think was your Jimmy/blazer, What is on the back, I couldn't make it out (something 2000) I think.
    <P ID="edit"><FONT SIZE=-1>Edited by Twiztid on 03/18/01 08:28 PM (server time).</FONT></P>
  2. Itali83
    Itali83 1/2 ton status
    Feb 12, 2001
    795
    Westbrook Maine
    Re: tailgate\'s
    I just replaced everything in my manual rear window, so I know how it goes. If you want to take the outside handle off, you need to take everything else out to get at it. Take the glass out first then the regulator and the two nuts that hold on the outside handle will be visible. It is acually easier that it looks. You need to take the seals that run side to side on the truck so you can slide the window out of the tailgate completely, that is the hardest part of the whole job because of those friggin metal clips!!!!! Hope this helps and if not write again and I'll answer your question.
    Ben 87 Jimmy
    "if it ain't got rust, it ain't got character."
    <A target="_blank" HREF=http://www.bens87toy.coloradok5.com>http://www.bens87toy.coloradok5.com</A>
