tailgates...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by solowookie, Mar 1, 2002.
  1. solowookie
    solowookie 1/2 ton status
    Mar 31, 2001
    3,880
    Wyoming
    ok guys... first of all how many stupid layers are there in tailgates?
    as some of you know I'm doing the paint prep work on my off-road k5.
    well here is my problem; there was some bubbling rust under my paint in the middle on the bottum (not very bottum about an inch up). well I'm thinkin I need to check out the inside to make sure I'm not getting rot from the inside.
    well I take the cover off the inside, and check it out finding no rust. well I should have been smart enough to check that out first, but I started stripping the paint, and when I got to this (it is in the middle) I got a big surprise. I found it rusted clean through 2 layers, and third below it. is this omething that can be repaired with a patch, or should I replace the fender?
    also, about 4" from it is a small spot (about the size of a pin head) that was a little rusty. that small spot had gone clean through the first layer.
    BTW how much is an aftermarket tailgate? I'm thinkin even if I can pick one up for cheap that I probably won't do it.
    <font color=blue> Jeff - may the force be with you</font color=blue>
    <a target="_blank" href=http://coloradok5.com/gallery/Jeffs-Stuff>link to k5's</a>
  2. CK5
    May 19, 1999
    21,627
    704
    CO
    Here is a pic of my tailgate, I guess I don't have any paint problems: <a target="_blank" href=http://coloradok5.com/temp/reartire2.jpg>http://coloradok5.com/temp/reartire2.jpg</a>
    Steve
    Director of Global Expansion
  3. solowookie
    Mar 31, 2001
    3,880
    Wyoming
    LOL - yea I don't think you have any paint problems... [​IMG] I do wanna stop the rot, but I'm not going to spend enough on a paint job I will be afraid to use it.
