taillgate window will not go up with key
Discussion in 'The Garage' started by blazerjake86, Oct 12, 2003.
  1. blazerjake86
    blazerjake86 Registered Member
    Oct 12, 2003
    19
    i put key in the tailgate and turn nothing happens I read about cleaning the contacts but i am not sure. can someone point me in the right direction. thnks
  2. Espen88k5
    Espen88k5 1/2 ton status
    Feb 19, 2000
    981
    Norway
    I have the tailgate tear-down on the link below, with pictures!. Hope it helps.
  3. scrappy88
    scrappy88 1/2 ton status
    Mar 14, 2003
    314
    Loveland, CO
    There's a lot of things it could be: Blown fuse, bad key switch, bad safety switch (won't let you roll up the window with the tailgate down), bad motor, faulty wiring somewhere. Start narrowing it down so you know where to look. Does the window roll up using the switch in the cab? If it does, then it's probably the key switch. Not too bad to replace. I've had to do mine before.
    Also, welcome to the site! /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  4. blazerjake86
    Oct 12, 2003
    19
    yes it goes up with the switch
  5. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    That link doesn't work...
