taillight wiring stuff
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by blazinzuk, Mar 24, 2003.
  1. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    My brakes lights don't work I checked most of the obvious stuff fuse little switch on the brake pedal grounds Wiring doesn't apperard to be corroded or cracked all grounds seem to be intact. I do have taillights just not turn signals or brakelights. Oh year I did rip the taillight off on a rock Any suggestions would be great /forums/images/graemlins/rotfl.gif
  2. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    Does anything happen when you hit the emergancy flashers?
  3. Phreak480
    Phreak480 Registered Member
    Dec 13, 2002
    36
    dix hills, ny
    check the wiring in the dash on the side of the column
    i ahd the same problem i had marker lights but my brake /directional didn't work on the right taillight n it was a loose wire in the plug on the column
  4. jwingfield2k
    jwingfield2k Registered Member
    Jan 29, 2003
    29
    Richardson, Texas
    get a wire tester, and start from the engine and just see where the signal stops, thats the best way to do it. step by step, inch by inch
