tailshafts(same or different?)
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by promudder1, Jan 13, 2002.
  1. promudder1
    promudder1 1/2 ton status
    Nov 18, 2001
    208
    would a np205 froma fourspeed work on a th400 if you had the adapter from a th400, are they the same spline count and size, i want to put a np205 from a stick behind my th400 that came with a 208, if i buy the adapter new from gm would it go together? has anyone done this before? i love throwing crap together it is such fun!
  2. tRustyK5
    Jul 23, 2000
    36,169
    1,372
    E-town baby!
    A lot of the SM 465's came with 10 spline output shafts. If the SM 465 was from a newer truck with a NP208 behind it or a NP 241 it will be 32 spline just like the TH400 version 205.
    The adaptor I don't think is available new anymore...but I could be wrong.
    Rene
    <a target="_blank" href=http://coloradok5.com/gallery/project_T2> tRusty pics...</a>
  3. promudder1
    Nov 18, 2001
    208
    the 205 is 1975 version havent seen it yet to check spline count. the th400 is 1985 model
  4. tRustyK5
    Jul 23, 2000
    36,169
    1,372
    E-town baby!
    You'll have to swap the input's on the 205 to the female 32 spline input. The case will need boring as the bearing is a little larger.
    The face of the 205 will need to re drilled for the correct adaptor I think...
    You could ask Stephen Watson for more specifics...or even do a search through the ORD forum for more info. I'm sure I recall it being covered at least once.
    Rene
  5. RGF
    RGF 1/2 ton status
    Jan 5, 2001
    281
    Maine
    The 75 205 will have a 10spline input gear, to make that work behind a TH400 that had a 208 you will have to completely tear down the case and have it bored for the bigger 32spline input/bearing plus buy the correct adapter. You are looking at somewhere around $400. just to do that, they have 2 different 32spline inputs a long and a short one. You will need the long version so you dont have to change out the output shaft in the TH400.
    I would keep looking for the right transfer and save yourself some headaches and money in the long run,unless your planning on rebuilding the transfer anyways.
    The military pick-ups used TH400s with 208s and 205s and it appears that all the trannys were the same shaft stick-out but they could use either transfer.
    I just fiqured this out a couple weeks ago and Ive been around for awhile, learn something new everyday!
    RGF
  6. promudder1
    Nov 18, 2001
    208
    thanks for all the info guys!
