Take a look at my shaft, and tell me what cha think
Discussion in 'The Garage' started by MEGALADON, Jul 30, 2005.
  1. MEGALADON
    MEGALADON 1/2 ton status
    Feb 4, 2005
    214
    HOUSTON
    I had a problem finding a short shaft for a 700R-4, and finally found one.
    I thought I could put it in myself, because I really did not want to pay over 150 to get it installed :rolleyes: , But I decided to let a shop do it. the trans came out a 91 camaro, the shaft, im not sure, but they said it would work on my 91 trans. I did buy it from a trans shop..
    Well, now some shops tell me the shaft may not work, because of different count of splines :doah: , the guy at the trans shop, told me they were all the same :confused: ...(where I bought it from)
    This is the thing, can you tell buy looking at it?? I'm not sure, I'm not a trans expert :( I don't want to pay $167.00 to find out I need a different shaft.
    Some trans companys told my my front pump would not hold up to a truck :(
    Are they trying to SHAFT ME???????????????????
  2. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    Nice red x's :crazy:
  3. MEGALADON
    Feb 4, 2005
    214
    HOUSTON
    they are showing, must be your computer. :screwy:
  4. tx_sub
    tx_sub 1/2 ton status
    Mar 5, 2004
    548
    Denton, TEXAS
    same here
  5. tRustyK5
    Jul 23, 2000
    36,170
    1,376
    E-town baby!
    They only show for you because they're cookied on your computer. The rest of us see red 'X's.
    Rene
  6. MEGALADON
    Feb 4, 2005
    214
    HOUSTON
    I think I fixed it, anyone else having problems??? :doah:
  7. blazerpro79
    blazerpro79 1/2 ton status
    Jan 4, 2005
    528
    Simi Valley, CA
    I see them... but unfortunatly can't post any advice, because I dont knwo. but yes the pics are fixed.
  8. MEGALADON
    Feb 4, 2005
    214
    HOUSTON
    THANKS BLAZER :thumb:
  9. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    I'd have the shop that sold you the shaft do the swap, that way if it doesnt work, its their fault, tell them that they ordered the wrong part, its their responsibility to get the right one to make it work.
  10. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    that would be the 4wd shaft for a 700r4, they are all the same spline. the only spline that ever changed on the 700r4/4L60/4L60E, is the input from the converter, they changed that is mid 84.
    as for the pump, :haha: :haha: :haha: the pump has nothing to do what application its in, its the year. they first started with a 7 vane pump, weak, not much pressure and wore out fairly quick. then is 86, they put a 10 vane in. this pump is what most of the trannys have, good pressure and lasted a long time. in 95 or 96 they put a 13 vane pump in. GREAT pressure and last along time. its nice to have but oyu don't need it unless you are running big HP.
    sounds like the tranny shops are trying to scare you into letting them do it. if you have any questions on this shaft swap, pm, email me, im also on yahoo massenger under the same screen name. i have done this swap many times, and have rebuilt quite a few also.
  11. MEGALADON
    Feb 4, 2005
    214
    HOUSTON
    Thanks BIG :thumb:
