Taking a 1-ton and making it a 3/4 ton is.......
Discussion in 'The Garage' started by stallion85, Jun 27, 2006.
  1. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    getting to be a pain in my arse. Apparently I should have grabbed some leaf springs out of the JY since the ones on my M1008 are too wide for the D44. I had to get a JY steering arm, new brake calipers and pads, and now I have to get some front springs for this thing just so I can move it out of the driveway:doah: I should have just bought a D60 and matching 14ff to put in my K5 instead of this route............
    Alright my bitch session is over. Feel free to throw in your comments:D
  2. Paxx
    Paxx 1/2 ton status
    Feb 9, 2003
    1,405
    All Over Western Canada
    lol i guess it just depends on how much you end up getting for the m1008 when your done. I think by the time I finished getting my 60 under my front end it had cost me $1800cnd. I paid $1200 for the axle but it had the perches and shock tabs ground off for the guys link set-up so that was 4 bills at the machine shop and then the king pin rebuild kit and new calipers etc.
    Oh well the piece of mind is worth every penny :D
  3. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
    Werd!
    Is your rig going to be ready for the Bash, max?
  4. Paxx
    Paxx 1/2 ton status
    Feb 9, 2003
    1,405
    Thats what I'm shooting for. Only about $18000 more dollars to go lol.
    I need to stay in the bush and work a couple of 5 week hitches to afford it but it'll happen. My new oil rig I'm on is non-camp so that means an extra $125 a day (tax free) sub pay on top of my wage. So I figure with the hotel costing me $240 a week and shopping for food at costco I should be able to dump a lot more into the truck now.
    I figure this build is costing me about $32000 in total :crazy: :doah:
    I never figured buying a k5 would end up costing me so much money...
  5. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    ummmmmmm the springs are ALL 3" wide, 1/2 ton, 3/4 ton and 1 ton...
  6. GotLabs
    GotLabs 1/2 ton status GMOTM Winner
    Jul 30, 2005
    2,795
    Transient, USA
    Not so, mine were 2.5" wide. I had the same problem with my 44, I just "made them fit".:D Ubolts were angled bad, but they held, and I even drove it like that.
  7. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
    The first pick is the front springs for the M1008, the second set is some 52" 1/2 ton rear springs.........there is a 1/4" difference there.
  8. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
    Well I found out a few things today at the JY when I went to get some front springs. I looked at a few trucks 1/2 ton and 3/4 ton and they all had the same spring width as my M1008 which is 2 3/4". Then I went and looked at a couple K5's there and there front springs were 2 1/2". So before I started to slave away in the Hot Vegas summer with no impact gun, I had an idea to measure the spring plates........
    Wouldn't you know it they were the same size? One thing I did notice on the K5 compared to the trucks is that the gap between the u bolts in the springs were obviously closer.
    So I am now back here at home waiting for my bud to get off work so I can get those spring plates and see if this works.
    I also had to change the rubber brake lines to the calipers. The ones for a D60 caliper are square headed and the ones for a 10 bolt are the rounded ones. Luckily I kept the stock ones off the K5 and just put those on.
    Hopefully by tonight I will at least have the axle mounted and everything else but the brakes bleed...........The last pic is my work motivator:D
  9. 1-ton
    Apr 17, 2004
    2,890
    167
    Las Vegas, Nevada
    The stock front spring width on my SRW 1-ton crew cab is 2-1/2" (8,800 GVWR), but the stock front spring width on my DRW 1-ton is 3" (10,000 GVWR).
  10. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
    I dunno about this one, maybe because it's under a diesel???
  11. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
    Just in case anyone cares I got the 8 lug D44 finally bolted up tonight with a little help from my bud. Tomorrow I will bleed the brakes then take her for a test spin. The shocks on this rig are SHOT!!!! I can move them up and down with ease!!!!
    I don't think I will even bother with them since I have decided to sell it.......
