Taking apart and putting back together a 205?
Discussion in 'The Garage' started by chvyhs, Feb 12, 2004.
  1. chvyhs
    chvyhs 1/2 ton status
    Feb 12, 2001
    1,469
    Murrieta, California
    I'm about to take my 205 apart and have the bearing hole machined to fit the T400 input bearing. I just wanted to know if it's a pain to put the thing back together again? Is there anything to watch out for when I do this?
  2. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    There is some decent info in the Tech section
    205 tech
    I am about to swap a fixed yoke into my 205. Was just wonder the same. I am going to do it with T-case in truck though.
  3. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Naw, it's easy dude. The hardest part is getting the shims lined up for the counter gear shaft, just use lotsa grease. Grind the shift rails for twin stick while you have it apart /forums/images/graemlins/wink.gif
  4. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    It is a stupid simply t-case once you get into it...just make sure you have some real HEAVY DUTY snapring pliers. I think if you take it apart piecewise and lay out the parts in the order that they came out of the case you will understand exactly how it works and it will go back like clockwork...
    Chris
  5. chvyhs
    Feb 12, 2001
    1,469
    Thanks for the info. I had seen the 205 tech post before and didn't think about saving it at the time.
    This is going to be a doubler set up for my Suburban and I'm doing it all on a bench.
