Taking apart the door...
Discussion in 'The Garage' started by MountainMan, Sep 30, 2004.
  1. MountainMan
    MountainMan Registered Member
    Oct 9, 2000
    89
    Highlands Ranch, Colorado
    I am about to being taking apart my driver side door so i can replace the vent window. Are there tricks to pulling off all that interior paneling, do i need a special tool, or can i just give it a firm pull and it will come off (in a way that will allow me to put it back on later)
    THX /forums/images/graemlins/crazy.gif
  2. tx_sub
    tx_sub 1/2 ton status
    Mar 5, 2004
    548
    Denton, TEXAS
    after unscrewing the panel screws, and dont' forget the arm rest screws, there are two chistmas tree connectors on the panel. i forget where exactly they are but you can pry the panel back enough to see them. then pull those out. then lift upward on the panel. there are clips at the top where the window channel is. roll the winder down and git yer hand in there to pull it off.
    putting it back on is a pain to get everything to line back up. i replaced my front window seals several months ago.
    good luck
  3. Rolled
    Rolled 1/2 ton status
    Jun 16, 2002
    683
    Anchorage, Alaska
    There is a tool to remove those christmas tree (like stated above) connectors. Most auto parts stores sell them. You really only need one when the door panel is made of card board. If the door panel is plastic, you can get them out if you are careful...
  4. diesel4me
    Jul 24, 2003
    17,577
    945
    Massachussetts
    Call me a cheap prick,but when I needed a tool like that to pull my door panels off,and didnt have one,or the cash to buy one,I saw the cooking utensils hanging on my gas grill--the "pickle fork"looking thing usually used to stab your steaks worked perfectly!--I never used the fork for cooking anyway!--its now hanging over my workbench! /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/whistling.gif
