taking bedsides off
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bear76, Mar 7, 2007.
  1. bear76
    bear76 1/2 ton status
    Oct 16, 2005
    1,065
    here
    I know the bedsides on a k/c10 can be unbolted from the rest of the box, but has anyone done it? Also, does anyone have any links or resourses on this?
    Thanks.
  2. RGV72BLAZER
    RGV72BLAZER 1/2 ton status
    Jan 23, 2006
    2,425
    Edinburg*San Bene*Online-The Real South Texas
    i'm taking mine off with a sawzall and plasma cutter so that i don't ruin the paint. not sure if that helps. i know a guy here on ck5 did a pretty good write up on removing his bedsides but can't remember if it was on a pickup or blazer.......
  3. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    What do you need to know?
    The forward most section will be unstable if you remove the sides, otherwise you end up with a flat bed with fenderwells over the tires.
    I made that as a trailer but no use for me as a truck with no sides.
    It's all bolts so it's just a matter of unbolting them.
  4. k30bb468
    k30bb468 1/2 ton status Premium Member
    Oct 2, 2004
    955
    NW Pennsylvania
    The last bed that I took apart had some spot welds on the rear most crossmember where it joined with the bed side, just ground them off & the rest of it unbotled.
