taking d60 apart...need help
Discussion in 'The Garage' started by muddybuddy, Jan 13, 2006.
  1. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    hey there, i need to take my d60 apart to get geared this weekend. ive got the calipers off and the first part of the manual hubs off. i have the hub socket, but i tried fitting it in there and it wouldnt fit. is there a ring in it like the 10b? it got dark real fast so i stopped. ive taken a 10b apart, how much different is the d60? any help would be great.
  2. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    Once you have the locking hub off. This is what is on the spindle holding the hub/rotor on.
    http://www.partsmikeparts.com/60_spindle_nuts.jpg.
    It has the smooth nut, the washer, and then finally the nut with the little "tit" on it. Remove those and the hub should slide right off of the spindle.
    Ira
  3. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    alright, so it is exactly like a 10b. it jus seemed like there was something else in there too
  4. sweetk30
    Nov 1, 2004
    25,552
    547
    horseheads , ny 14845
    but do you have the 60 socket? its not the same size as 44/10 bolts. its bigger.
