Taking Off Top
Discussion in 'The Garage' started by humper, Jul 31, 2005.
  1. humper
    humper Registered Member
    Jul 6, 2005
    12
    Tennessee
    I just got my 71 K5 and was wondering how you all took your tops off and different methods of doing so. I was told it was quite heavy so i was looking for some advice as to how to go about taking it off.
  2. BurbLover
    BurbLover 1/2 ton status
    Jul 31, 2001
    3,060
    SW Missouri
    Welcome to CK5 :waytogo: You'll love it here. I've always wanted a Gen 1 K5. And since I don't own one, can't really help you out too much. :doah: Just wanted to welcome you here.
  3. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    2 people can do it, you'll just have to kinda learn how to hold it and walk it off the truck.
    a 3rd person would be handy too just to help lower it and whatnot.
  4. humper
    Jul 6, 2005
    12
    Tennessee
    ok thanks a lot for the help
  5. 6.2LTrailblazer84
    6.2LTrailblazer84 1/2 ton status
    Jul 4, 2005
    201
    san diego
    We should design a simple rig to remove the top. Some rig that anyone could make out of standard materials...
    Something that you attatch to the roof of your garage or covered parking..
    And/or something that you could simply drive out from under..
    Maybe there could be a CK5 design contest for it.. and the winner won something cool?
  6. humper
    Jul 6, 2005
    12
    Tennessee
    That would be a good thing to have...I dont think i can hold a contest for it though :wink1:
  7. perp
    perp 1/2 ton status
    Jul 14, 2005
    569
    Chandler AZ
    unbolt it.one person gets inside and bends over. stand in about the middle and extend your legs to lift the top with it flat across your back. have your buddy steady it so it doesn't tip to one side or you may end up with a new dent. walk to the rear a few feet and set it back on the rails, hanging off of the end a bit. then stand up and lift top between top and windshield, while buddy lifts at back. walk to end and set your end on tailgate. hop down and wrestle it to the ground. they are real heavy, so if your not real big, get two freinds. this is easier with the back seat out, but you can step over it
  8. uglyangelracing
    uglyangelracing 1/2 ton status
    Jun 6, 2005
    271
    Rhode Island
    I use to have an old winch in rafters of the garage and used 4 eye bolts in the cap. I think someone put the same idea in thehow to section
  9. humper
    Jul 6, 2005
    12
    Tennessee
    thanks a lot guys this is a ton of help
  10. 6.2LTrailblazer84
    Jul 4, 2005
    201
    san diego
    Humper, you have to hold the contest and give some great prize!
    Jokin.. :D
    I meant maybe the owner/s of the site would do something like that.. I thought I saw they gave out prizes for stuff.. I might be wrong though. :o
  11. humper
    Jul 6, 2005
    12
    Tennessee
    That would be a good idea if they do
  12. 3 on the tree
    3 on the tree 1/2 ton status
    Oct 16, 2004
    3,970
    gunnison colorado
    My 70 double wall has at least 16 bolts holding it on. The hardest part of removing it was finding all the bolts!!! My owners manual gives a weight of 225 pounds for the top, so its lighter than a full size fridge, just bulky and awkward. Me and 2 teens pulled mine off and just set it on 2 sawhorses.
  13. steve_kibbe
    steve_kibbe 1/2 ton status
    Feb 4, 2004
    2,895
    Spartanburg, SC
    Greg72 has a slick setup. Only thing you need is a tall garage ceiling.
    clicky
    if there was a contest, he would have already won :D
  14. humper
    Jul 6, 2005
    12
    Tennessee
    thats a pretty sweet setup...wish my garage was tall enough
  15. steve_kibbe
    Feb 4, 2004
    2,895
    Spartanburg, SC
    When I took mine off, it took me and a buddy to handle it. Its a double wall top. In the future I'm going to build something very similar to Greg72 so it can be done solo. My garage has a 12-13 ft ceiling :D
  16. BigCountryx
    BigCountryx 1/2 ton status
    Feb 19, 2005
    519
    Gonzales, LA
    Greg72 has built exactly what I have been working out in my head!!! That is sweet. My Garage ceiling is 10' should be plenty room I think.
    BTW - Contest over................Johnny, tell Greg72 what he has won :D
  17. koldsimer
    koldsimer 1/2 ton status GMOTM Winner
    Jan 10, 2005
    1,480
    texas
    Contrary to what some might tell you, the top CAN be removed by just you if you use the right technique. Unbolt it, pick it up off the locating pins and shimmy it back until it's at least half off the back of the truck. Let gravity help you ease it to the ground and BAM, the top is off! I've heard of busted side windows and cracked shells, so be careful. I do my top by myself all the time and my truck has 9" of lift and 42's. Oh yeah, it helps being 6'6" 240. Good luck bud!
  18. JEBSR
    JEBSR 1/2 ton status
    Dec 23, 2004
    1,541
    Clarksville, TN
    taking top off
    That is a nice setup but if your a cheap lazy individual like myself you can take 4 bicycle hooks (type that allow you to hang bike from ceiling) screw one in the rafters above each corner of your top , run two ratchet straps front to back one on left side and one on right pull the slack out and tighten two or three clicks then drive out from under it. Works great and is plenty strong. :D
  19. gjk5
    gjk5 3/4 ton status
    Mar 17, 2004
    5,312
    Grand Junction, CO
    Don't know if anyone mentioned it but it's much harder with a full cage as you can't just walk it back. Me and a friend just picked up the front and slid a 2x4 between bedside and top and did the same with the back and then we could slip our hands under and walk it off from the outside.
    Hope that helps.
    PS, don't forget the two "hidden" bolts at the back corners. :doah:
  20. 6.2LTrailblazer84
    Jul 4, 2005
    201
    san diego
    clicky
    That thing is an engineering Marvel! haha
    But I believe there is a simpler system that could be devised that you wouldn't need a high garage ceiling and would be easier and cheaper to manufactuer.. but this is just in theory.. so I could be wrong.. but there is no doubt.. either way.. that setup deserves somekind of Rube Goldberg award. :D
    It's like the real life Wallace and Grommet... :D
