Taking on water...
Discussion in 'The Garage' started by nad, May 16, 2006.
  1. nad
    nad 1/2 ton status
    Dec 29, 2005
    1,537
    Festus, MO
    Okay, so last Saturday, I took my truck to the annual mud bash to see what it had. It's been raining day in day out here, and I was told the "play area" was a bit flooded. Well that it was, and in order to get around from place to place there, you had to cross mid-sized puddles of water. Well after crossing them a few times to get from mud pit to mud pit, my motor died. It kept starting back up, but no matter how far I gassed it, it still wouldn't move, then it died again. I took the air cleaner lid off and found the air box full of water...
    Does anyone have any recommendations of how I can keep water from splashing into my airbox? I'm not driving through water up to my motor, but it is actually splashing in there. Thanks.
  2. jekquistk5
    jekquistk5 Weld nekid Premium Member GMOTM Winner
    Jan 18, 2004
    11,025
    852
    Pinckney, MI
    snorkle:dunno::dunno:
  3. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,924
    336
    Fort McMurray, Alberta
    Slow down. The faster you go, the higher the water climbs up the front of your truck, and the more likely you'll take water into the air cleaner housing.
    Also consider putting some splash gaurds on between the inner fenders and frame rails, along with making sure you've got a fan shroud to keep water from getting splashed up by the fan.
    Other than that, your only bet is a snorkle.
  4. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,230
    488
    New Hampshire
    Yeah I have had the same problem a few times before. I drive too fast. I am a speed junky thats why I don't like rocks.
    I was thinking of making a semi-snorkle where the intake sits on top of the front fender and bent so that it faces away from water flying up. I would love a snockle but I don't want to cut any holes in my bodyfor it to come through.
  5. Janitorjim8
    Janitorjim8 1/2 ton status
    Feb 21, 2005
    215
    Illinois
    Snorkel, or some people have run their intake into the cab with an open element filter on the end, but with that you have to worry about backfiring... Also I have heard of putting pantyhose on the front of your intake duct, that will stop some.
  6. broncoman6524
    broncoman6524 1/2 ton status
    Oct 31, 2005
    2,469
    chuluota Fl
    Is there a reason you couldnt use the stock filter assy. Cut off the yolk part that sticks out and face it towards the firewall. Sure it wouldnt get as much air but you could turn it around just when your playin
  7. redneckdude
    redneckdude 1/2 ton status
    Feb 21, 2004
    578
    Augusta, GA
    i ran a dryer duct hose off the end of my stock air cleaner assembly and have it run between the battery and coolant overflow. It doesn't keep 100% of water out but it helps out A LOT.
