Taking out a 3" body lift
Discussion in 'The Garage' started by blazin topless 75, Feb 6, 2004.
  1. blazin topless 75
    blazin topless 75 Registered Member
    Feb 5, 2004
    47
    Connecticut
    Taking out a 3\" body lift
    I want to take out the 3" body lift on my truck. I've never done anything like it before and have a few questions: Where can I find a poly bodymount kit for it? I've searched the net for a couple of days and can't find a complete kit including the bolts.
    What else is involved with it? I can assume that there will be some steering adjustment to go with it, shift linkage replacement (it's an automatic). What else do I need to do? Any thing you guys can tell me would ba a great help. I've got 6" of suspension lift and I want to run 35s on it without looking too top heavy...
    Sean /forums/images/graemlins/dunno.gif
  2. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    Re: Taking out a 3\" body lift
    you wont have to replace any linkage or correct for steering, but adjusting the linkage may be necessary.. post the year and model of your truck and someone will point you in the right direction for all the parts you need..
  3. blazin topless 75
    Feb 5, 2004
    47
    Connecticut
    Thanks. It's a 75 Blazer.
  4. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    im sure Off Road Design can throw a set of bushings and bolts together for ya /forums/images/graemlins/waytogo.gif
  5. Confedneck
    Nov 1, 2002
    5,236
    check them out
    PST ^^ can put together a kit for whatever you need..
  6. monsterjim
    monsterjim 1/2 ton status
    Feb 5, 2004
    151
    north Texas
    Shouldn't have any problems, the tranny linkage will be fine, they may or may not of put a steering spacer in, just look at the steering shaft and see if there is a 2 inch spacer on it before it gets to the steering box, shouldn't hurt to leave it on. The e brake cable may of had a bracket put on it and that will need to come off, usually along the frame, under the driver door. Also look to see how the fan shroud accomodated the fan, there may be spacers splitting the top and bottom halfs. To find the bolts, might just post it on here, plenty of guys put lifts on and may have kept thier old bolts.
  7. wolfy87
    wolfy87 Registered Member
    Jan 30, 2004
    32
    near Dallas, TX
    I'd check that shifter linkage very close. I helped a buddy put a body lift on an 88 Chevy truck which I'm sure has a similar linkage set up. Whe had to cut the linkage and weld in a 2" filler piece that came with the kit. Look for the weld. Also look and see how the fuel tank filler neck has been modified/ lengthened. Should be easy to revert to stock. Also check the fan shroud and radiator mounting as there are spacers/ brackets that had to raise those because they are affixed to the body. /forums/images/graemlins/doah.gif
    It would be valuable to get your hands on the instructions for a body lift for a K5 so you can go in and make sure you've accounted for all the modifications. /forums/images/graemlins/cool.gif
