taking out auto hubs *WHAT AM I DOING WRONG???*
Discussion in 'The Garage' started by Lotsa_Faith, Jan 17, 2003.
  1. Lotsa_Faith
    Lotsa_Faith 1/2 ton status
    Jul 10, 2001
    474
    Mckinney, Texas
    i am having a 24-hour brainfart and I don't know how to get the auto hubs out to replace them with some warn hubs. I took off the cover, took off a rubber o-ring along the outside that was held in place by a little clip, now how do i get the auto hub body out? /forums/images/graemlins/blush.gif
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Look closely near the outer edge of the hub body. You'll see two little pieces of steel peeking out of a notch in the hub body, perhaps 1/2-inch away from each other. Those are the ends of the 3-inch diameter wire ring that holds the hub assembly in place. Squeeze 'em together with a needle nose pliers and the hub body will slide right out. /forums/images/graemlins/thumb.gif
  3. K5on38s
    K5on38s Registered Member
    Dec 11, 2002
    90
    Buffalo, NY
    after you take the little clip out there are 2 little eneds sticking out where it was push em together and pull it out (i just did this a few days ago....but no my hubs sound like ratches so i donno) /forums/images/graemlins/confused.gif
  4. ramjet gmc
    ramjet gmc CK5 Staff Staff Member Moderator GMOTM Winner
    Dec 19, 2001
    3,370
    Milltown NJ 08850 NJ sucks
    I feel your pain I spent a ton of time trying to find mine and when I found the ring I thought that would be it but it was some aftermarket piece of junk I bought the small pliers kit from sears no good a $2.00 pick did the job /forums/images/graemlins/eek.gif
  5. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    You will also have another snap ring behind the hub body you will need to take out to put in manual hubs. just FYI. It is just like the first small one on the axle shaft.
  6. Rob 85K5
    Rob 85K5 1/2 ton status GMOTM Winner
    1,487
    Pensacola, Florida
    Auto hub exploded view
    [​IMG] /forums/images/graemlins/grin.gif
  7. 87sm465np208
    87sm465np208 1/2 ton status
    Aug 28, 2002
    1,114
    illinois
    yea i could see a problem if you've never done hubs, i took out and installed my friends New warn lockouts for him in 40 minutes /forums/images/graemlins/wink.gif.
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/truck.gif
  8. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Part number 9 in the exploded view is the ring I was talking about. You can't see it very well in the pic, but on auto hubs the ends of that ring are bent 90 degrees so they stick out where they're easy to grab with the needle nose pliers. /forums/images/graemlins/cool.gif
  9. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    You dont have a picture of warn/locking hubs like the one you have with auto hubs do you?
  10. Rob 85K5
    1,487
    Pensacola, Florida
    Nope.
    After the lock nut is torqued correctly, then insert the hub, Install hub ring #9 in the pic, install the axle snap ring if required or possible(can't in an '85), install hub face and install allen head bolts.
  11. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    I had never done hubs, replaced mine in a little under an hour...
