taking out interior today, what's this thing?
Discussion in 'The Garage' started by emoo99, Sep 15, 2004.
  1. emoo99
    emoo99 1/2 ton status
    Jan 16, 2003
    494
    Washington
    taking out interior today, what\'s this thing?
    It's on the passenger side lower kick panel plastic molding thing, has kinda a scoop over it but it's a thing that open and closes, i took the whole panel off and looked inside the big hole and found alot of mud, leaves, dirt and all that crap just sitting in the inner corner panel, in the hole there's a propeller looking thing.. anyone know what this is and if i can just patch up the hole and paint over it?
    I took out all my soakin wet moldy carpet and now taking the kickpanels off to trace some leaks and i'm wondering what to do about this thing now...
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Re: taking out interior today, what\'s this thing?
    That would be called a Kick panel air vent. When you move your heater selector to vent, that metal canister(diaphragm)opens that door and lets air into the cab.
  3. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    and IIRC it pulls air from the cowl
  4. emoo99
    Jan 16, 2003
    494
    Washington
    hmm, so without it there, and just an open hole will i constantly get air into the cab? i guess my lazy self can go drive and see but i'll ask instead..
    and if i stop that propeller with expanding foam or something so it doesn't turn is there another vent anywhere to get air from? cuz my vent heat works alot better than my heater heat.
  5. dyeager535
    26,980
    If you are gutting the AC system, you can pull the vent out of a non-AC truck and use it instead. Uses a pull handle instead of the heater/AC controls.
    Not much point to welding the hole up, stuff is still going to pile up in there, might as well be able to get at it and clean it out.
