Taking out the tranny
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by KrebsATM02, Aug 11, 2000.
  1. KrebsATM02
    KrebsATM02 1/2 ton status
    Mar 21, 2000
    553
    College Station, Texas
    I am swapping my 700r4 tommorow for another one and i have never done it on a 4x4. I think i am going to have to drop the transfer case as well. Any one have any tips Thanks - Doug Krebs
    Doug Krebs
  2. bart
    bart Registered Member
    Mar 15, 2000
    69
    Eastern PA
    I think it would be best for you to drop the transfer case then remove the transmission...I think trying to do it all in one would be too heavy. (I'm trying to remember my brother's k5 with the auto...I have a manual)
  3. 6.2 man
    6.2 man 1/2 ton status Premium Member
    636
    Curtis , WA
    I've tried it both ways . Taking the transfer case off is best .With it on makes everything to unstable .
  4. James
    James 1/2 ton status
    Jun 22, 2000
    179
    Castaic, Ca
    krebs,
    I just finished last wknd taking out my th350 and 1st my np203 t-case. If yours is set up anything like my set. You almost have to. T-case bolts to adapter, adapter bolts to the tranny. Adapter is mounted to the crossmember support. Anyways now is a good time to check the seals on the t-case and replace if needed and check the shift linkage as well. Only advise I can give is if you do take out the t-case and crossmember, under no circumstances should you allow the tranny to support itself from the bell housing only. Always keep a jack underneath supporting the tranny. Might have someone help you with t-case. Did mine by myself not to smart. Chest was little bruised up for next two days. Tranny jack a plus(really makes it easy) or you can take off the top round disc on your reg jack and bolt a 2x6 x 18in long and balance the tranny on it . Just take it slow. anyways good luck
    Peace
    James
