taking out true-trac
Discussion in 'The Garage' started by Bhintz, Jul 10, 2003.
  1. Bhintz
    Bhintz 1/2 ton status
    Mar 28, 2003
    1,341
    Roswell, Ga
    trying to get trutac out of 10bolt to sell but cant remove axles, I think you push in axles and remove c-clips but cant push axle in enough to get to them. Am i doing this right or am I screwing something up? /forums/images/graemlins/1zhelp.gif
  2. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    Look for a small bolt going into the housing, I think it takes like a 5/16'ths wrench. Remove this bolt. next, slide out the cross-shaft then you will be able to slide axles in.
    Look it over good first, and have a plan, you don't want to have to put the shaft back in at a weird angle. You want it to slide out right at you.
  3. Thumper
    Thumper 1/2 ton status
    1,582
    Alberta Canada
    My Trutrac has a block between the axles. You have to remove the allen Hex head bolt right in the center of the unit, then the metal block comes out. Then you can push in the axles and get the c-clips out.
    Mike
  4. Bhintz
    Mar 28, 2003
    1,341
    Roswell, Ga
    got it thanks /forums/images/graemlins/thumb.gif
