taking the doors off
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by silver, Sep 5, 2002.
  1. silver
    silver Registered Member
    Jun 8, 2002
    72
    Dallas Texas
    how hard is it to take the doors off my 70 blazer and how long does it take?
  2. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    I can have them off in under 5 minutes with a cutting torch. but really all you have to do is unbolt them, either at the door or behind the fender
    the door side would be the easiest and quickest it's just a matter of getting it to line back up once you put them back on if you plan to
  3. jeffro
    jeffro 1/2 ton status
    Jul 2, 2002
    406
    Scurry, TX
    I drove the pins out of the hinges on my toyota and replaced them with removable pins. This makes easy work of removal an reinstallation. I don't know why it wouldn't work on a Chevy.
  4. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,140
    14
    Bangor,Pa
    it only takes a few minutes.it helps a lot to have a friend there so youy can have him hold it up when you take out the final bolts.the door weighs about 50 pounds or more.i have done it myself but its not much fun.gotta hold the door in one hand and the ratchet in the other so the door doesnt fall to the ground as you pop the last bolts.
