Taking the grill off
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Mudstud, Aug 5, 2001.
  1. Mudstud
    Mudstud 1/2 ton status
    May 29, 2001
    1,472
    Memphis, TN
    I'm putting on a tranny cooler in front of the A/C condenser and would like to know if you guys have any tricks for unbolting the grill. I've got a Hickey tube grill and the hardware that they supplied utilized the square nuts (not hex nuts) making it more of a pain to work with. It's just too tight to get my arm all the way up there from underneath. Even if I could I couldn't turn the screws with a screwdriver. Can't turn the square nuts either cuz of the tubes in the grill. I figured I could drill some holes on the radiator cross member to get a tool in there from the rear but the way the metal is folded it will limit my reach plus the radiator gets in the way. I had my little nephew with me when we put the grill on so he could reach up there and hold things while I tighten it all down. Any ideas?
    Stuck is a state of mind!
    Mudstud
    76K5 sb400/350/203parttime/3.73-D44/GM12 locked
  2. mpascino
    mpascino 1/2 ton status
    Jan 1, 2001
    557
    Connecticut
    if it came down to it you could unbolt the radiator and AC core and reach around. I;d say it would be better than cutting eye soring holes. Once you get it off replace the square nuts with hex ones too.
    My two sense,
    Mike
    You call that dirty!?
