Taking the input out of a 241...
Discussion in 'The Garage' started by mikey_d05, Jul 11, 2006.
  1. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    Can one easily remove the input shaft from an NP241 through the front of the case? I have the retainer plate off and the two lock rings out. There is a significant amount of end play in the input shaft but the bearing is refusing to move.
    Is there something I'm missing?
    Can I even take the input shaft out of the front of the case?
    Should I shut up and get a bigger hammer?
  2. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
  3. 88-383
    88-383 1/2 ton status
    Sep 11, 2005
    142
    Tracy. CA
    Dont use a bigger hammer! Why not split the cases? or am I missing something here. I dont think that shaft will come out oterwise.
    KM
  4. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    I said the hell with it for the night. I don't want to open up the case because that's an absolute **** ton of work to replace an input shaft. Especially considering I have to switch it to another case which has to work. So that means I have to break down and rebuild two 241's on Saturday. Faaaaaaaaaannnnnntaaaaaaaastic.
  5. NateInChandler
    NateInChandler 1/2 ton status
    Apr 23, 2006
    418
    Chandler, AZ
    Its been a few monthes since i did mine but i believe you half to split the case.. there is a snap ring on the rear of the case in the tailhousing also that you half to remove... getting it back together (if you somehow got it apart without splitting the case) would be a bear... no way of telling if you got everything back where it goes... Nate
  6. jays68yak
    jays68yak 1/2 ton status
    Feb 27, 2003
    973
    Gilroy, CA
    yeah you have to open the case. Its easy man shouldnt take but more then a few hours to get the 2 apart and back together.
  7. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    Well, looks like I'm gonna be splittin two 241's just to swap the inputs.
    Kert, why couldn't you just have a passenger's side drop case? :doah:
