taking the top off??
Discussion in 'The Garage' started by 82K5_6.5L, Mar 11, 2003.
  1. 82K5_6.5L
    82K5_6.5L 1/2 ton status
    Dec 4, 2002
    439
    Tucson, Az
    its getting hot out and i want to take the top off my blazer, my neighbor has a Jimmy and never takes his off because he says when u take it off it never seals right and leaks..is this true? anyways i dont care, still gonna do it anyways..!! /forums/images/graemlins/k5.gif
  2. Kyle89K5
    Kyle89K5 1/2 ton status
    2,273
    OKLAHOMA
    I've had mine on and off a dozen times with no leaks. As long as the weatherstip is still in good shape where it seals, you shouldn't have a problem.
  3. 4x4dreamer
    4x4dreamer 1/2 ton status
    Jul 8, 2002
    874
    St. Petersburg, FL
    aren't we supposed to chant, "show your seats!" or something like that?
    Thank you, thank you, I'm here all week! /forums/images/graemlins/grin.gif
  4. rebelk5frk
    rebelk5frk 1/2 ton status
    Dec 29, 2001
    815
    Houston, TX
    If a Blazer's top wasn't supposed to come off then they wouldn't have made it removable. /forums/images/graemlins/rolleyes.gif /forums/images/graemlins/rolleyes.gif
    Mine is off more than it's on during the warmer months. Take it off and enjoy.
  5. Blazinaire
    Blazinaire 1/2 ton status
    Mar 17, 2002
    1,262
    Santa Maria, CA
    Like many other people here my top is off the /forums/images/graemlins/k5.gif on a regular basis /forums/images/graemlins/cool.gif. It is still using the factory weather stripping and seals with ZERO leaks. The key to getting a proper seal is when you put it back on make sure to park on a level surface (to prevent body flex) and tighten down all of the bolts against the back of the cab before tightening any of the bolts on the bedrails. P.S., be sure that once you take the top off to tell your neighbor he is a wanker /forums/images/graemlins/rotfl.gif
  6. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    According to my '77 GM service manual, when removing the top on a K5 you should fabricate 2 braces 72"s long withn 3/8"s holes at 63"s apart. these braces should be attached at the front and rear of the top to keep the sides from flexing while the top is off the truck. they recomend using square aluminum tubing for the support braces. /forums/images/graemlins/thumb.gif
  7. wa_jeeper
    wa_jeeper Registered Member
    Mar 3, 2003
    85
    Great Lakes, IL
    Since I've been down here in Texas, the top of my K5 is in the garage at least 8 months out of the year. And I don't have any leakage problems... yet.
  8. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    One of my K5 owners manuals had the same thing in it. The problem is, you would have to break to top to fasten it to the bolt holes only 63 inches apart. The correct measurement is 68 inches. /forums/images/graemlins/eek.gif
  9. 85HeartBurb
    85HeartBurb 1/2 ton status
    Jan 10, 2002
    735
    Temecula, south
    definatly take it off! /forums/images/graemlins/usaflag.gif
  10. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    82K5, I shoot my seals really well with 409 or windex brfore I pop the lid. It gets them wet and they don't have a tendancy to tear. I do the same when I replace it too. Be sure to get the bolts from the bottom of the lid in the rear too!!!! Very important. IO saw you signed up on WheelingArizona, now come in and say hi. Theres a trip to Martinez this weekend. I'm not going but I may sneak off to Reddington for a little bit.
  11. schmuck
    schmuck 1/2 ton status
    Nov 11, 2002
    523
    nola(new orleans LA)
    taken mine off a dozen times in the last 2 years with no leaks, if you get a bunch of rattles with it off try putting the bolts back in the retainers tend to rattle around
