Taking the truck to a FLEXOFF
Discussion in 'The Garage' started by AnthonyG, Nov 10, 2003.
  1. AnthonyG
    AnthonyG 1/2 ton status
    Jan 26, 2003
    339
    Gillette Wyoming
    I havn't been on here for a while so i will tell you all about my truck then ask for help
    It is 85 GMC 2500
    It has a lincon locked 14bff
    open D60
    built th400 with shift kit and an alison converter
    454 going in this weekend
    4" springs up front
    shackel flip with 4 leaf pack and 2" block for added flex ability
    trimmed fenders up front and no box and bobbed frame
    and finaly 38.5x15x16.5 groundhawgs
    I am going to a flexoff on the 29th and i am trying to get ready so i need some sugestions for added flex
    ok with the box and front shocks on i could pick up 1 rear tire 4.5 feet off the ground befor lifting a tire
    I took off the box for now ( i am waiting for more $$$ to build a flatbed)
    I am going to take the front shocks off
    I am not running rear shocks right now
    my question is will i pull a tire off the ground with no weight on the back and what els can i do to flex better
    let me know your ideas
    anthony
  2. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    having the bed of will make your frame flex MAD. i would put a 300lb weight on the frame as well. use the springs as much as possible.
    Grant
  3. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    I would drop a few pound of air in the front drivers side and rear passengers side tires (those are the ones you would run up the ramp). /forums/images/graemlins/thumb.gif /forums/images/graemlins/grin.gif
  4. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    felxoff huh? better hope da knight isnt there...
    /forums/images/graemlins/wink.gif /forums/images/graemlins/laugh.gif that rig is so damn cool... /forums/images/graemlins/thumb.gif tires dont even appear to be particularly aired down either. yikes... prolly only stopped cause the ramp was about to end...
    j
  5. Emmettology 101
    May 9, 2000
    8,126
    FL
    I wouldn't drive without your front shocks. Maybe take them off when ya get there...
    One thing that will help ya flex is opening up or removing your spring clamps all together! My are off in the rear and opened in the front...
    Also, make sure your spring bushings aren't over tightened. Maybe even lube them up...
    And like someone else said, drop your air pressure. I run 35x15.50x15 TSLs on a 15x10 rim and have goen down to 9-11 psi without problems.
  6. chubbybob
    chubbybob 1/2 ton status
    Oct 18, 2002
    730
    just remember there arent any ramps while your out wheeling. and short wheelbase rigs might have half the suspension travel you do but they will score higher just because your so long. half the rigs in my club are jeeps and when we are out crawling I can out climb and go over way more things than they can but on a ramp I can just score a 1000 when others score better.
  7. AnthonyG
    Jan 26, 2003
    339
    Gillette Wyoming
    ok my spring clamps are already off and it helps quite a bit.
    my tires are 16.5's so i can't air down too much
    the truck is living on a trailer for a whils so i won't be driving it up there it is about 90 miles or so to the flexoff
    well we will see what happens and take lots of pics
    thanks
    anthony
