talk to me about PTO winches...
Discussion in 'The Garage' started by colbystephens, May 3, 2008.
  1. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    10,924
    13
    Oregon
    i'd like to run a PTO winch on my blazer - is it possible to run a winch that is mounted to the front of my truck with a PTO? i understand that the pto runs another driveshaft, but what type of winch would i procure? does the PTO then determine the pulling capacity of the winch?
  2. dremu
    Feb 27, 2000
    15,710
    93
    East of San Francisco
    The pulling capacity would be determined by the torque of the PTO, sure, but is more affected by the gearing of the winch. Consider it like your axles, right -- torque delivered is a function of the torque at the transfer case multiplied by the gear ratio.
    Except your winch should have a ratio in the hundreds-to-one :D so you end up with crazy numbers.
    And yeah, I've NO idea how you'd get a PTO shaft to a front winch on our trucks. You generally see them on tow truck for the mid-mount winch, or on the big military trucks (i.e. 2 1/2 ton aka "deuce and a half" or larger.)
    What's wrong with your basic normal electric winch?
    -- A
  3. smalltruckbigcid
    smalltruckbigcid 1/2 ton status
    Dec 25, 2004
    3,866
    3
    NE Wyoming
    run the PTO from your trans (sm465) and the shaft goes forward to the winch. That means you need a PTO for your trans and a shaft you would need to build or have built. It would only turn when the PTO was engaged, cab controlled by you.
    The PTO bolts to the side of the tranny case where the cover is, thats what the big flat plate with 6 bolts in it is for. Since you want the shaft going forward you want a reverse mounted one, usually they are mounted with the shaft going to the rear. That probably won't be cheap or easy to get, well maybe easy but not cheap. For the headache involved I think unless you found a used takeoff setup complete I would go electric or hydraulic. If you go hydraulic you want one that is not run from your PS pump, rather a real dedicated pump.
    Last but not least if you run anything but an electric you HAVE to have the engine running or you have no winch
  4. BILTIT
    BILTIT 1/2 ton status
    Mar 27, 2007
    702
    Lloydminster,SK
    I have a PTO for the front, came off a pickup. I have seen two in my lifetime so they cannt be that hard to find, hehe. The PTO you want mounted on your transfercase instead of the tranny, better setup in my opinion. This way you can winch and/or winch and drive where as a PTO on the tranny only turns when driving, i believe.
    The shaft runs to the front with a steady bearing on the driverside frame. The main downfall of a PTO is the low spot on the winch where the shaft attaches.
    PTO winches are rated per the winch, they have shear pins which are supposed to shear at a certain force to prevent over torqueing. Many people report that PTO winches never shear at the correct force and will pull much more than they are rated for.
    PTO's can be run hard and all day long, since they have a ~300HP motor driving them, not much stalls them unless the motor stops. They can be dangerous because they do not stall, this is why many do not like them. It is harder to gauge the amount of torque on the line because of the lack of stalling.
    There is a connect/disconnect on the PTO under the truck (cable or shaft shifted) and a connect/disconnect at the winch.
    They are bigger than an electric, thus they are heavy and usually require a hefty bumper to hold them.
    http://www.putfile.com/pic/7044585
    1 ton with pto winch in front, see the guard on the low spot in front?
  5. dieselponyexpress
    dieselponyexpress 1/2 ton status
    Jan 26, 2004
    220
    Germany
    Nice! :eek1: I bet you could push a train with this bumper. :bow:
    Walter
  6. BILTIT
    Mar 27, 2007
    702
    Lloydminster,SK
    Probably, most refer to is as a cow catcher haha. I have removed all grill guard (vertical) peices and have just the regular bumper now, sill waiting to put it on.
  7. colbystephens
    Feb 24, 2005
    10,924
    13
    Oregon
    i found two of them here in oregon for $200 or less in good shape... military issue. that low point does worry me tho. thoughts??
  8. dremu
    Feb 27, 2000
    15,710
    93
    Consider that $200 will buy you an 8274 or the like ... admittedly maybe one that needs a bit of love, but that's gonna be cheaper than a driveshaft, PTO setup, etc.
    -- A
  9. colbystephens
    Feb 24, 2005
    10,924
    13
    Oregon
    true, but these are 30K lb winches.
  10. dremu
    Feb 27, 2000
    15,710
    93
    Oh god. Have you SEEN those? I don't think they'd FIT on our trucks :haha:
    -- A
  11. BILTIT
    Mar 27, 2007
    702
    Lloydminster,SK
    My PTO is an 8K and it is larger in diameter than my warn 10K, shorter in length though.
  12. greywolf
    greywolf 1/2 ton status
    Oct 18, 2001
    1,606
    ST.PAUL TX USA
    is that a tulsa pto winch? looks like mine:D 8000lb tulsa pto.i have the levers and everything.
  13. colbystephens
    Feb 24, 2005
    10,924
    13
    Oregon
    hmmmm... well, that would be a bummer. :haha: no, i haven't seen it's size in person... just a pic with no reference on it.
  14. dremu
    Feb 27, 2000
    15,710
    93
    Never mind the weight -- not just the winch, but the cable. A 30K would be on a deuce-and-a-half, say, so I'm gonna WAG we're talking about 1/2" or bigger cable .. and ~100 feet of that stuff ain't light.
    I know people talk about hydraulic winches and how electrics suck and blah de blah ... but ya know, there's a reason why there's so dang many electric ~10Kish winches out there. They're relatively cheap and easy to install, simple, easy to fix, did I mention simple? =))
    -- A
  15. UPS
    UPS 1/2 ton status
    Aug 2, 2006
    438
    Maine
    The PTO on the trans of my 1 ton dump truck works in neutral and first gear. I haven't tried it in any other gear.
    Mike
  16. BILTIT
    Mar 27, 2007
    702
    Lloydminster,SK
    You bet, 8K tulsa.
  17. BILTIT
    Mar 27, 2007
    702
    Lloydminster,SK
    Hmm, i will have to find that info again.
  18. BILTIT
    Mar 27, 2007
    702
    Lloydminster,SK
    So i found abit, I was wrong. The PTO style will determine which drive (tranny or tcase) you use.
    ''tranny mounted pto speed is determined by engine rpm, direction (fwd/rev) is determined by a 2 direction pto box.
    transfer mounted pto speed is determined by the transmission gear. i.e. 1,2,3,4,R. ''
  19. Chevy911
    Chevy911 Registered Member
    Feb 6, 2006
    78
    Grand Portage , MN
    I've got a 10,000 pound ramsey PTO winch mounted on my blazer, its probably about half the speed of my warn M10000 on my pickup, but I never have to worry about burning solinoids or overheating it. Running the shafts wasn't too difficult, I've got a 2 piece shaft with a slip, and a pillow block mounted to the engine crossmember. the only mod is grinding out the existing hole in the forward frame crossmember for more clearance around the shaft. Also I've got a chelsea PTO mounted on my NP205 with a SM465, allows for 4 forward speeds, and the manditory ability to power out cable with reverse, since you cannot disengage the winch drum with any tension on it at all. Although I only use 4th gear for actual winching, and 1st for spinning the winch slowly so I can get out and engage the drum. One other bonus, I always remove my warn from my truck when I'm not using it, for fear of it getting stolen, but the PTO winch is permanently installed, and so difficult to remove, that I always have it, come in very handy when you don't expect it.
  20. greywolf
    Oct 18, 2001
    1,606
    ST.PAUL TX USA
    sweet! now i know who to talk to about them.do you have any picks of it mounted???
