Taller tires
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by rh88k5, Sep 11, 2002.
  1. rh88k5
    rh88k5 Registered Member
    Sep 11, 2002
    94
    Burlington, N.J.
    I just bought an 88 k5, it has 265/75 r 15's, I want to put 33x10.5's on the stock 15x7 wheels, my question is how much effect will this have 0n my speedometer and will I need to change the speedo gear in the tranny to compensate?
  2. Suffergauge
    Suffergauge 1/2 ton status
    Aug 1, 2002
    153
    Olympia, Wa.
  3. MudbogAD
    MudbogAD 1/2 ton status
    Jun 29, 2001
    672
    Las Vegas Nevada, US
    I wouldn't change a speedo gear because your speedo will hardly be off.
  4. dyeager535
    26,976
    Difference at 2000RPM is going to be about 4MPH, and at 60 it will be 5MPH. (3.73 and 1:1 assumed axle/tranny ratios, and assumed as advertised tire diameter)
    If you want an accurate speedo, you can either change gears, or find some "adapters" GM used on some trucks and cars, which change the "output" of the speedo driven gear, so you don't have to change the driven gear at all. Not to mention, the 265's you have on there now already have changed the speedo, (235x75R15 or 31" were both "stock" or optional sizes) so it will be even further off when you go to 33's than what my example was.
  5. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    with only 33s i wouldn't bother, i'm running 36s and i haven't changed anything for my speedometer.
  6. dyeager535
    26,976
    Yeah you are only off by 11MPH@2000RPM if your stock tire was 235x75R15, 1:1 tranny and gears are 3.73, plenty to get a speeding ticket on the freeway in some states.
  7. BigBadCad
    BigBadCad 1/2 ton status
    Dec 18, 2001
    109
    minneapolis, mn
    You could also try running the cable directly into the T-case without the speedo gear. Mine ended up dead on (verified by GPS).
  8. MNorby
    MNorby 3/4 ton status Premium Member GMOTM Winner
    Dec 10, 2001
    6,125
    53
    Powell, Wy
    I ran 265's for a while and it wasn't a big difference. Ran 35's w/ 4.10s and it pretty much equalled to being correct too. Then I put a TH400 and lost the speedo all together, just go with the flow of trafic /forums/images/icons/smile.gif
