Tandem axle suspension
Discussion in 'The Garage' started by dremu, Jan 18, 2006.
  1. dremu
    Feb 27, 2000
    15,958
    452
    East of San Francisco
    Mulling ideas around in my head, and I see on the USA6x6 site this thing (attached).
    I guess it has a solid link (green) along with the leaf spring up top (orange), and some kind of panhard thing (blue)? Would you call this a three-link leaf-sprung setup, or what?
    Any ideas, input, pointers to other varieties of tandem axle suspensions, and/or web pages with pretty pictures of same for us visual learners, much appreciated. No need to go into USA6x6, I've read all those posts ... just happened across these pix there is all.
    -- A
  2. boz42
    boz42 1/2 ton status GMOTM Winner
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    get out & go look at some dump trucks & tractor traailer trucks. there are tons of ways to set up tandem axles. i don't know what u are trying to do here but that would bea good place to go look. we have 4 dump trucks & i tractor trailer.
    some have 4 leaves some only have 2, some have air bags & some have rubber cushion bushings for springs.
    most that use leaves have a anti-wrap bar of some type. most airbag susp. use a 3link set up. were 2 bottum links are hard mounted to the axle & swing from the frame from a bushing end. those will have a panhard bar on top.
    i like the way Macks are set-up. they have a camel-back leaf on each side that is upside down compared to our trucks. the axles are mounted to the leaf ends in a leaf under design. the leaf is mounted to the truck frame at its center. where it mounts is a pivet so the axles can swing up & down
    this isn't a very good pic but the only one i could find in a hurry
  3. Eric M.
    Eric M. 1/2 ton status
    Dec 10, 2001
    2,118
    Oakland, CA
    I shoulda showed you the axle sitting in my garage.
    Eric M.
  4. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    My computer refuses to load Pirate right now but there's a guy building a 6x6 on there with 2 D70's. He's just using two 4 links, one right behind the other with a carrier bearing for the 2nd shaft (using a hyrbrid 200/205 with twin rear outputs) mounted on the first pumpkin.
  5. dremu
    Feb 27, 2000
    15,958
    452
    Thanks guys. I'm just contemplating what would be involved with a tandem conversion on a pickup, which implies somewhat smaller axles and suspension than in the medium duty stuff.
    Eric, do tell about that axle!
    -- A
  6. boz42
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    eric m what kind of axle is that? custom?
  7. dremu
    Feb 27, 2000
    15,958
    452
    Yeah, I had heard from Kyle @ NWF about the NP200 with dual rear outs... MikeyD05, I dug on on Pirate, but I found a ton of unrelated crap. Do you have any further details so I can narrow my search, or link to the specific thread?
    -- A
  8. MNorby
    MNorby 3/4 ton status Premium Member GMOTM Winner
    Dec 10, 2001
    6,126
    53
    Powell, Wy
    back in the day like 10 years ago I remember reading in dad's farming magazine about a chevy that someone tandem axled and made into a service truck. I beleive he used 2 NP205s, one forward then one backward and 2 14FFs. Maybe look back into old Hay and Forage mags.
