Tank swapping... help
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 71Blazer, Dec 21, 2002.
  1. 71Blazer
    71Blazer Registered Member
    Dec 17, 2001
    24
    Coupeville, WA
    Are sending units interchangeable between carbureted and fuel injected gas tanks?
    I have a 31 gallon tank from an '84 (carbureted) Blazer. I want to put this tank in my '71 (w/fuel injection). Is there a FI sending unit from a later model that will fit? /forums/images/graemlins/confused.gif
  2. Langosta39
    Langosta39 1/2 ton status
    Nov 8, 2002
    156
    Moscow, Idaho
    What kind of fuel injection is it that is on a 71? If it is something aftermarket like Holley Projection then your sending unit should be fine. If it is some factory stuff that is retrofitted then I don't know. Is the fuel pump in tank on your fuelie? If not then I think you are alright. I assume you don't have both of them to compare...
    andy
  3. dyeager535
    26,982
    191
    Assuming you know that there must be some fabriction to get the 73+ tank to fit, TBI fuel senders work from '87-91, and for high pressure applications, a Camaro pump should work good for you. (I'm betting the truck TBI pump is the same part # as a Camaro TBI pump part #, but don't feel like looking it up on www.carparts.com )
    To be honest, I don't have a Camaro pump yet, but if GM stayed true to form, car TBI/TPI pumps fit the same sending unit, so the trucks will too.
    '87-91 K5 tanks are different than 73-86(and earlier of course) as the TBI tanks are baffled to make sure the pickup isn't uncovered when its low on fuel, cornering, extreme angles, accelerating, etc. Doesn't seem to be a problem for some people running without them, but GM felt it necessary in every single fuel injection application they made.
  4. 71Blazer
    Dec 17, 2001
    24
    Coupeville, WA
    It'is a TPI unit from an '86 Vette. The pump I have is external but I have to run a fuel return line which the FI sending units are already plumbed for. The 31 gal. tank would give me much needed fuel capacity /forums/images/graemlins/crazy.gif
  5. 71Blazer
    Dec 17, 2001
    24
    Coupeville, WA
    As long as the flange on the '84 tank will accept a later model (FI) sending unit I can make a baffle for the fuel pickup. I may just have to go down to the friendly auto parts store and compare side by side. Thanks for the input
