Tank swapping...help
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by 71Blazer, Dec 21, 2002.
  1. 71Blazer
    71Blazer Registered Member
    Dec 17, 2001
    24
    Coupeville, WA
    Are sending units interchangeable between carbureted and fuel injected gas tanks?
    I have a 31 gallon tank from an '84 (carbureted) Blazer. I want to put this tank in my '71 (w/fuel injection). Is there a FI sending unit from a later model that will fit? /forums/images/graemlins/confused.gif
  2. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Ther should be. I put a brand new 31-gallon Blazer tank in my Crewcab. It was supposed to fit 81-91 Blazer and Jimmy. I installed a sender from an 87-91 Burb. The same years Blazer/Jimmy one should be identical.
  3. blueturd
    blueturd Registered Member
    Dec 3, 2002
    88
    Arvada, CO
    You might want to check to see if your fuel injection needs to have the sending unit in the tank w/ a fuel pump in the tank. Might cause it to vapor lock without it
  4. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color="blue">It'll work
