tansfer case fluid
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by kustom71, Dec 18, 2003.
  1. kustom71
    kustom71 1/2 ton status
    Mar 14, 2003
    117
    NJ
    I know it has been covered but i just checked out my gm service manual and for a full-time tansfer case it says motor oil,for a part-time case it says gear oil.My question is if you convert a 203 to part-time shouldnt you use gear oil then??????Truck is 77 /forums/images/graemlins/truck.gif
  2. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    10W-30
  3. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
  4. lukebaby1
    lukebaby1 1/2 ton status
    Dec 16, 2003
    231
    Richmond, Virginia
    10w-30 synthetic
  5. crazy427
    crazy427 1/2 ton status
    Mar 10, 2003
    979
    Edison , NJ
    10w-30 synthetic
    IZZ Slipperierier
  6. kustom71
    Mar 14, 2003
    117
    NJ
    ok thanxs just wanted to check!!!!!!!!!!!!!!!!! /forums/images/graemlins/rotfl.gif
  7. lukebaby1
    Dec 16, 2003
    231
    Richmond, Virginia
    10w-30 synthetic will take heat better too. doesn't break down as easy a mineral oil /forums/images/graemlins/angryfire.gif
  8. K30CJ
    K30CJ 1/2 ton status
    May 16, 2003
    429
    IN
    Good timing for this post. I was checking over my '78 beater that I just bought, and found it had gear oil in the NP203. It has a part time kit in it, so I was wondering if gear oil was recommended after the kit was installed. I'll change it to 10W30 syn.
