Tap and Die sizes
Discussion in 'The Garage' started by 77crewcab, Aug 17, 2005.
  1. 77crewcab
    77crewcab 1/2 ton status
    Feb 9, 2004
    1,620
    Lubbock, Texas
    I am looking to buy a tap and die set, can someone tell me what sizes I need for a big block. I don't really understand what the sizes all mean or what would be needed, I just need a list of required sizes so I can make sure they are included in the set I buy. Thanks!
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    When I bought my set yrs ago, I got one that goes from 6-32 clear up to 1-X(can't remember the TPI on the 1" one)but that is for a complete set of TAP and DIES.
  3. 77crewcab
    Feb 9, 2004
    1,620
    Lubbock, Texas
    which ones are actually used for our engine though?
  4. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Prolly only the ones from 1/4" - 5/8"
  5. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    On chevy's you will need, 1/4"-20, 5/16"-18, 3/8"-16, 7/16"-14
    The 1/4"-20 will do all valve cover bolts, timing cover bolts, and all oil pan bolts with the exception of the 4 corner bolts which are 5/16"-18.
    The 5/16"-18 will do the 4 corner oil pan bolts, cam gear bolts, oil filter adapter bolts, and also a few plug wire loom bolt holes on the sides of the block.
    The 3/8"-16 will do all motor mount bolts, water pump bolts, bell housing bolts, intake manifold bolts, and exhaust manifold bolts.
    The 7/16"-14 will do all main bearing bolts, oil pump bolt, and head bolts.
  6. 77crewcab
    Feb 9, 2004
    1,620
    Lubbock, Texas
    Thanks that was exactly what I was looking for including going so far as to tell what fits where. Very helpful! :saweet:
