Taper on Superlift 1104 arm correct for MOOG 2027L DLE?
Discussion in 'The Garage' started by IGOR, Aug 12, 2003.
  1. IGOR
    IGOR 1/2 ton status Premium Member
    May 16, 2000
    2,303
    19
    Damascus, OR
    I talked to Scott at Rockstomper today, and he said that the 1104 pitman arm needs to be opened up approximately 0.030" to seat the DLE correctly - I thought I had read on here that these were a perfect match - any thoughts? /forums/images/graemlins/confused.gif
    What if I didn't drill these out 0.030 - would it make that much difference? /forums/images/graemlins/thinking.gif
  2. Waxer
    Waxer 1/2 ton status Author
    1,857
    Long Beach, CA.
    Yes it will make a huge difference. Right now you can't get the ES2027L in deep enough for you to tighten the nut and align any of the holes for the cotter pin.
    You can't just "drill" it out either. You either need to have it tapered down some more at a machine shop that has the correct taper reamer, or just run one of the dodge ends that will fit right into it perfectly. ES2010L is the end you are looking for.
  3. IGOR
    May 16, 2000
    2,303
    19
    Damascus, OR
    Cool okay thank you! /forums/images/graemlins/thumb.gif
  4. IGOR
    May 16, 2000
    2,303
    19
    Damascus, OR
