Tapered Block Installation
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by TowRig, Dec 20, 2001.
  1. TowRig
    TowRig Registered Member
    Sep 4, 2001
    7
    Wisconsin
    Well:
    I'm on the tail end of a RC 4"-lift install and am wondering if I installed the re axle blocks correctly. I installed them with the thinner edge toward the transfer case. Any feedback would be appreciated.
    Kevin-
    1986 CUCV Military Blazer, T400 trans, 3.08 gears (yeah, I know....good mileage though), No camo, US Customs took care of that
  2. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    yeap thats the right way, it cuases the axle to turn up so the angles is right on the driveline.
    <font color=red>Life is like a mud hole:</font color=red><font color=blue>
    When the S#!T gets deep, you have to keep moving and friends can always pull you out</font color=blue>
    55 Willy's
  3. Pure Insanity
    Pure Insanity 1/2 ton status
    Mar 17, 2001
    4,579
    Dade City, Florida
    Sounds like you got it correct, but make sure the tapered end is on the axle side. You want the square end against the spring and the taper towards the axle. That way it tips the pinion up, and not moving the axle back. The blocks in the rear of mine were installed upside down when I bought it.
    If ya can't stop.......Smile as you go under! [​IMG]
    PIC of mine from flblazers site<a target="_blank" href=http://www.flblazer.alloffroad.com/photo3.html>
    GO</a>
