Tapping a D44 knuckle
Discussion in 'The Garage' started by Dallin, May 1, 2006.
  1. Dallin
    Dallin 1/2 ton status
    Feb 12, 2003
    135
    Yes I've searched. I need to do the job tonight while I have a mill available. What is the dimension from the ball joint hole to the line between two of the steering arm holes? Most of the drawings I've seen leave this dimension off. Does it deepend on the arm you use? I plan on using Sky arms, but I don't have them yet. I'm sure a little clearance grinding will fix any interference, but I'd like to get close.
  2. Dallin
    Feb 12, 2003
    135
  3. virgilh
    virgilh 1/2 ton status
    Sep 8, 2004
    343
    Sacramento California
    i would look at your drivers side knuckle because its a mirror image of it. :D
  4. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    1.75"
  5. Dallin
    Feb 12, 2003
    135
    Thanks, exactly what I needed.
