Taurus Electric Fans (2wire & 3 wire)
Discussion in 'The Garage' started by Hossbaby50, Oct 26, 2003.
  1. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    While junkyarding today Shawn and myself ran across some electric fans from Ford Taurus's. We found a 3 wire fan which are 2 speed right? 2 wire fans are 1 speed correct?
    Will a 1 speed fan cool a K5 in primary cooling? How many CFM does a 1 speed fan pull? How many for a 2 speed? How many amps for a 1 & 2 speed?
    I was thinking about using my stock fan for primary cooling and running a 1 speed Taurus fan for additional cooling of the ATF and when going slow. Will they work as a pusher fan? Thanks
    Harley
    P.S. I did search around but couldn't find any solid number on the taurus fans. Thanks
  2. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    not much help, but I can answer your 1st question... yes, 2 wire fans are 1 speed... 3 wire fans are 2 speed. lots of peeps over at POR seem to dig taurus fans... ya might do a search over yonder.
    hope it helps,
    j
  3. mofugly13
    mofugly13 1 ton bucket of rust Premium Member
    Oct 6, 2002
    2,813
    San Francisco
    Try this . I don't know about running it backwards as a pusher fan. When I was testing mine I wired it backwards and when it ran it made a nasty buzzing sound, so I disconnected it.
