tb cable? 700r4
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by sorryofficer, Dec 19, 2002.
  1. sorryofficer
    sorryofficer Registered Member
    Jun 23, 2002
    18
    arizona
    i have an 87 jimmy with a 700r4 and it isnt shifting right. I was told to adjust my TB cable is that the same as a detent cable?
  2. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    You're talking about the TV cable (stands for throttle valve I believe). It connects to the throttle linkage just behind and to the driverside of the TBI unit. To adjust...there's a tab that can be pushed in to unlock the cable. Then, you cycle the pedal to the floor, and you're done...it will lock itself back in position.
    Sorry if that was a crappy job of explaining....Haynes goes over it in their repair manual if you need visualizations. Otherwise, if you just need a little more clarification, just ask.
