TBI 350 and 700R4
Discussion in 'Engine | Tranny | T-case' started by mikey_d05, Jun 23, 2006.
  1. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    Up for sale is the TBI 350 and 700R4 pulled from '89 Blazer. Both are in great shape. I pulled them because I found a Caddy 500 and TH400 to use. The motor is complete. The throttle body and sensors are still there, the only thing missing is the ECU because I need it to inject the Caddy motor. If you want, I'll even pull the chip out of it so you know you have the right one. IIRC the motor was rebuilt at 50,000 miles, the truck had 120,000 on it before I dismantled it. Also, it's a complete serpentine setup. Only thing missing is the A/C compressor and it would be extremely easy to make a few cuts and bolt up a York in it's place.
    The 700 never skipped a beat, runs great, shifts well, doesn't leak, etc. It had an NP241 behind it before I pulled it off. (I'm reusing the 241 on my next build) It had a factory cooler on it and all the lines are still there. It also comes with the 700 to 241 support rod that a lot of chevy guys seem to be after. IIRC it was rebuilt at 70,000 miles.
    The price for the combo is $700 OBO. I'm located in New Ulm, and prefer not to ship if possible. I will however drive to deliver within a reasonable distance.
    The only things needed to make this combo run again are an ECU, fuel pump, and transfer case. Would be a great setup to swap into a Jeep or Toy. I will have pictures in the next day or two.
  2. RGV72BLAZER
    RGV72BLAZER 1/2 ton status
    Jan 23, 2006
    2,425
    Edinburg*San Bene*Online-The Real South Texas
    if only you were in TX...ttt for ya
  3. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    Somebody close by needs this. C'mon guys, here are the pictures.
    EDIT: Almost forgot, it's a K-case 700.
  4. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    TTT...the same stuff would cost $1200+ in a junkyard around here.
  5. Tim L
    Tim L Registered Member
    Jan 22, 2006
    33
    Colorado
    Where is New ULM ?
    Tim
  6. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    what bout the 27spline 241? im lookin for one :)
    *edit* jus reread you post....DOH
  7. K5Chris
    K5Chris 1/2 ton status
    Mar 11, 2002
    805
    New Orleans, LA
    what he said. :doah:
  8. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    New Ulm is in Minnesota. Sorry guys.
    If anyone is interested in shipping I'll drive to the nearest forward air terminal and give you a price break.
  9. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
