TBI 454... bad hesitation. Just doesn't "open up"
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by mountainexplorer, Apr 27, 2004.
  1. mountainexplorer
    mountainexplorer 1/2 ton status
    Nov 14, 2001
    4,903
    Spokane, Wa./Ione, Wa
    TBI 454... bad hesitation. Just doesn\'t \"open up\"
    What would cause a TBI motor to just bog down when stepping on the gas?
    It does it really bad when it's cold. Idles fine, but when you go to give it gas to accelerate, it just bogs down. If you really get on it, it sounds like you can hear the butterflies on the TBI unit open up, but it doesn't do anything. If you just barely step on the gas, and accelerate slowly, it seems fairly smooth. It seems to improve when the motor is totally warmed up, but it still doesn't open up like it should.
  2. Topdown
    Topdown 1/2 ton status
    Nov 26, 2002
    2,598
    Vancouver, Washington, U.S.A
    Re: TBI 454... bad hesitation. Just doesn\'t \"open up\"
    black smoke from the tailpipe? - running too rich, it will bog like a mofo
    No black smoke from the pipe? - May be running too lean, it will bog like a mofo here too...
    Thats all the thoughts I have... hope it helps.
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Sounds like a vacuum leak is a very likely culprit.
  4. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    When was the last time you changed the fuel filter?
    Might also be a bad TPS. Is it throwing any codes?
  5. mountainexplorer
    Nov 14, 2001
    4,903
    It doesn't blow any smoke at all.
    I'll have to check for vacuum lines being disconnected or broken, but I can't hear anything like air hissing.
    First thing I'll do is check the fuel filter.
    I'm sure it just needs a tune up too. Just got the thing, and I'm trying to get it running good before my friend gets it.
  6. reeser
    reeser 1/2 ton status
    Oct 8, 2001
    434
    Hayden Lake, ID
    why haven't you asked me????? /forums/images/graemlins/dunno.gif /forums/images/graemlins/dunno.gif /forums/images/graemlins/dunno.gif
    i just went through all of this with mine! i bet it is the MAP sensor, that is what solved mine after i replace EVERYTHING. also, go to schucks and they have a scanner you can use to run codes and figure it out the technical way. /forums/images/graemlins/waytogo.gif /forums/images/graemlins/peace.gif
  7. mountainexplorer
    Nov 14, 2001
    4,903
    I guess I just forgot.
    Shouldn't you be in class right now?
  8. reeser
    Oct 8, 2001
    434
    Hayden Lake, ID
    haha!!!
    well i'm finishing up a huge project due this afternoon. you got to have priorities in life!
  9. mountainexplorer
    Nov 14, 2001
    4,903
    You must be in the library. I drove it past your house a bit ago and didnt see the truck.
    How much was the map sensor when you bought it?
